Old 09-11-2020, 02:46 PM
brentwood brentwood is offline
High idle help
I've had an issue with my 401 idling way too high since I bought my truck.
I replaced the intake manifold gasket, replaced valve cover gaskets, replaced carb, carb adapter, and gaskets.
I fixed timing.
It starts right up and runs strong. It idles just a little too fast at start up, but sounds good. The warmer the engine gets, the faster it idles.
I've sprayed all around the carb and intake without any changes.
I've replaced main vacuum lines and plugged unused ports.
What do you guys suggest I should do/look at next?
Appreciate any help.
1982 Wagoneer w/258, Rusty's 4in spring lift, motorcraft 2100, 32x11.5x15 bfg's *sold*
1972 J4000 Chevy 350, th350, divorced Dana 20, Holley carb, alcan 4in springs, 35in BFGs on 15in slots
1978 J10 golden eagle w/Levis interior, 401and th400, Edelbrock avs2, 32x11.5 falken rubitreks on stock golden eagle wheels
Old 09-11-2020, 11:24 PM
What carb is on it?
Old 09-12-2020, 06:32 AM
Edelbrock 1906 avs2 650cfm
Old 09-12-2020, 06:44 AM
How much higher is the idle? a couple of things come to mind, look at your idle adjustment screws make sure the tips are not broken off and then inspect the inside of the venturi and look at where the idle screws are to see if the holes are ok and not broken out or enlarged( from over tightening it). Then look at your idle screw, where is it set, if you have a vacuum leak and you have to crack the blades open to far you can roll out of the idle circuit. Is the linkage for fast idle out of adjustment? Check the booklet from edelbrock that came with the carb, can be helpful.
Old 09-12-2020, 10:57 AM
Thanks for your reply. I have the idle speed screw backed out all the way. Idle at cold start is between 900-950. As the engine warms up, it gets closer to 2000 rpm.
It idled way too high before I replaced the carb but I didn't think much of it because it wasn't running right in general.
The fuel pump looks to be newer.... Is it possible it's pushing too much fuel pressure to carb?
Old 09-12-2020, 11:09 AM
verify the throttle cable/linkage/return spring are allowing throttle to close all the way.
seen it several times where a cable wasn't allowing throttle to fully close.
Old 09-12-2020, 09:10 PM
78 WIDETRAC's Avatar
This is just a shot in the dark, but what about a leak between the intake and block on the backside? It is a pain to spray in an exact spot back there.
The reason I mention this is.... My 79 has a high idle due to a massive vac leak! I can see the front intake rubber gasket is sort of twisted and squished out so it has no chance of providing a seal. I personally use RTV not the provided rubber seals, so this is on the list to change now that I got it running.
All bad info.... See post #9 My apologies
Old 09-13-2020, 06:48 AM
The idle screws should only be backed out 2-3 turns from seated position on both sides, not all the way out, which will cause the idle speed to be high.
Old 09-13-2020, 12:28 PM
this is not a vacuum leak. that end seal is an oil seal not a vacuum seal.
Old 09-13-2020, 12:36 PM
I'm not sure why I thought that. Thanks for pointing that out. The entire motor would be on vacuum if that were the case. You probably typed what others were thinking when they read my comment.
Old 09-13-2020, 08:35 PM
ckiczenski's Avatar
ckiczenski ckiczenski is offline
I know you said you tried spraying break cleaner around gaskets to see a change in idle & find a vacuum leak. But I would really recommend throwing a vacuum gauge on it and seeing what it reads at idle. They are relatively cheap if you don't have one. It really sounds like a vacuum leak somewhere to me
Old 09-14-2020, 06:20 PM
I have the idle mixture screws just over 2 turns out.
I ordered a vacuum gauge, some vacuum connectors and a fuel pressure regulator.
I'll report back with what I find.
Old 09-16-2020, 05:31 PM
That was it!
I believe I have the timing and carb settings pretty good. Starts right up idles right around 900. Manifold vacuum is right around 19hg. Sounds good when I hit the throttle.
Now it doesn't want to go into gear. Sounds like it's stuck in-between gears and grinds when I put it back in park. Didn't have this issue before I don't know if I messed something up when I was cleaning up vacuum lines or if it's just bad timing. Finally get it running good and it doesn't want to move. Haha
Old 09-16-2020, 06:29 PM
Mine does that when the transfer case shifter is in neutral. Make sure you are in normal or Low...
Old 09-18-2020, 11:27 AM
You guys are awesome. Really appreciate the help. Going to fine tune it. Then start prepping for raptor liner
Ported or manifold vacuum to the Dizzy? rang-a-stang General FSJ Discussion 20 02-15-2017 03:21 PM
Recent high idle issues hmmm crazyspoons General FSJ Tech 3 12-14-2011 11:35 PM
High idle not wanting to kick down Scott General FSJ Tech 5 05-04-2005 05:38 AM
High speed idle sticking? Mike111 General FSJ Tech 3 12-05-2003 07:13 PM
Idle speed too high Dan General FSJ Tech 13 09-18-2001 05:00 AM
