Old 05-24-2017, 06:27 PM
Tte531 Tte531 is offline
Noob!
Cam Swap
Im reading alot about cam getting swapped but im not seeing much about doing it with the AC condenser in place....
I found one guy who said just lift it up enough, well thats not real specific.
I wouldnt normally care but I tracked down enough R12 to get it charged last summer. Prefer not to have to find someone capable of removing it.
So question, can I swap cams with the AC condenser and does anyone have info on that.
Thanks!
1983 Wagoneer Limited 5.9L
Old 05-25-2017, 06:05 AM
The guy is right
You can do it with the condenser hooked up. You'll need the grille and radiator removed then you and loosen some of the brackets that hold the AC lines to the valence/core support, unbolt the condenser, and sort of lift it up out of the way a bit and hold it with a bungee. Do the same for your trans cooler if you have one.
-Jonny B.
AMC 401 - Pro-Flo 4 EFI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Steering colum swap question derf General FSJ Tech 15 02-04-2010 09:01 AM
Muncie SM465, GM 10 bolt 8.5, GM 14 bolt 10.5 and NP 208 swap Chris Barry General FSJ Tech 9 02-26-2007 03:25 PM
my experiences with a 14bolt swap into a cheif malodin Off-Road FSJ Tech 7 01-31-2007 10:54 PM
Turning Radius, Pitman arm? Steering swap. Louiseven General FSJ Tech 5 11-30-2006 12:25 PM
