Old 04-02-2017, 09:42 AM
Tte531 Tte531 is offline
Noob!
Deep Pan/Crossmember
Ok so i know this has been asked but im not getting a definite answer from the threads.
1983 Wagoneer Limited 5.9L
First off the pan.
I bought a B&M aluminum trans pan. It wont pass the valve body and crossmember to fit. I could probably install a new trans mount and it might pass BUT im afraid the clearance would be to close in case i was to flex something to far between the trans mount and crossmember and crack the pan. Is there another aluminum pan that will clear more easily?
Second, lets say there isnt a better pan...
How about fabing up a new crossmember that would allow for the pan to be easily installed and dropped in case i needed too. PLUS i could make the crossmember to allow for a skid plate to be adapted to it when i go back to Ouray.... Has anyone done this? Made a crossmember that is.
Third...
Should i just return the aluminum pan and get a P3690730AB steel pan from Mopar, and not adjust the crossmember. It would be less work and cheaper... but would it be less beneficial in the long run... i mean at that point should i keep the stock pan and go on with my life?
What say you ? Thanks for any input.
Old 04-04-2017, 03:17 PM
Darwin1876 Darwin1876 is offline
I have a deep pan on my TF-727 on my 88 Grand Wagoneer. My didn't clear either. So removed the lower bolts or nuts I can't remember which it has. Used a jack and a block on the transfercase. Jacked it up a couple inches installed the pan torqued the bolts and set the mount back down and reinstall the bolts or nuts.
78 J10
88 Grand Wagoneer
89 Grand Wagoneer
72 J4000
64 J200 (parts truck)
Old 04-06-2017, 05:01 AM
Marineviper's Avatar
Marineviper Marineviper is offline
Maybe find a pan off of a 45re from a 2nd gen ram. Same bolt pattern as a 727 and deeper. I don't know how much more than 727 or how much less than b&m.
76 j10 short, 360 nailhead th400 D20, 3.54, 4" lift, 31" bfg ko2
HEI
CS130 105amp
Comp cam sk10-200-4
Edelbrock performer w/1406
Old 04-07-2017, 01:12 AM
Noob!
Did it put the pan super close to the crossmember? Like close enough that if the drive train flexed on that bushing the pan would hit? Think thats my concern but i am installing a new trans mount bushing.
That would probably be cheaper... I wanted to use her to pull my old airstream around (not a large one) or my trailer so i wanted to keep her as cool as possible. thats why i chose an aluminum pan...
Old 04-17-2017, 02:30 PM
cma's Avatar
cma cma is offline
So how did it ends up?
Markus!
Picture story:
Old 05-24-2017, 04:28 PM
Noob!
Ok so i ended up just jacking up the transmission and installing a new poly mount. This raised the trans up considerably but still not enough to fit the pan.
It looks like if i remove some of the fins it might fit but i hate to try, fail and be unable to return it.
Its looks like an old user 'Hankrod' claimed he had done it but appears to be banned lol so just my luck....
Is the deep pan worth it for teh 727? Yagan General FSJ Tech 10 02-10-2012 08:28 AM
Deep Transmission Pan ottocycle General FSJ Tech 18 10-21-2010 07:21 PM
83 J-10 Deep transmission Pan/Crossmember? jlewis General FSJ Tech 8 07-21-2009 04:50 PM
TH400 deep pan clearance seventynine General FSJ Tech 1 05-18-2009 09:34 AM
Prepping for deep water crossings grand_wag_85 Off-Road FSJ Tech 18 04-18-2007 04:14 AM
