I have been trying for the last two days to get a 360 from the '79 into the Wag and it just does not fit. The eng mounts in the wag are lounger. They are 7 3\4" and the ones from the cherokee are 6" the frame is the same distance between the two. I just wanted to piont this out in case anybody else wanted to try this. I am in the process of trying to take the mounts off the wag. The ones on the cherokee were bolted in and the ones one the wag are put on with BIG rounded rivets. I went out today and bought an air compressor and I am going to try to chisel them off.
One other thing I noticed is that the cross member on the wag is forward more. I am going to have to drill holes to mount in the TH400. I did get a floorshifter today so I will not have to change the steering column (I like the old one). I did change out the brake pedal though and took out the clutch pedal which is to be expected.
My plans to have it on the road soon will have to wait. My only concern is how am I going to get to work?
'67 Wagoneer
'79 Cherokee Chief
Swapping parts so I will let you know the stats when I am done.
"I regret that I have but only one paycheck to give to my Jeeps."
'67 Wagoneer
'79 Cherokee Chief
