I've got the typical ATF leak from tranny to QT. Leaky at the gasket.
I was aware that the seals in the QT are prone to damage. I tried my best to not damage but I was solo on install and that is heavy. So finally to my ?..
Is the leak at the gasket due to a gasket? I'm going to go with a thicker gasket, smeared with something. Or is the ATF leak from a damaged seal and its leaking at that pin hole which I made sure not to cover when I installed the new seals. Either way I will again install new seals and gasket.
Thanks for your time.
