Old 12-13-2011, 01:22 PM
rileydcasey's Avatar
rileydcasey rileydcasey is offline
Interior Heater Core
Hey everyone,
I've been working on gutting out the worthless parts of the interior in my 77 J10 and found something a bit surprising. On the passenger side of the Jeep, there was an entire heater core and blower fan tucked up under the dash. I'm pretty sure it's aftermarket, but the vents that fit just below teh factory dash sure looked like they belonged there. Anyone have any information on these things?
Old 12-13-2011, 01:37 PM
autoarcheologist's Avatar
autoarcheologist autoarcheologist is offline
I'd love to see some pics. My big complaint about the Jeep's HVAC is that they're separate, I can't use the A/C to dry the air while defrosting. Although I have been mulling over some ducting ideas to see if I can achieve that.
Looking for Jeep enthusiasts to check out Jeeps and other classic cars and trucks for potential buyers. Learn more at www.jewelorjalopy.com
1973 Jeep Wagoneer Custom - 360 4V - sold
1974 Alfa Romeo Berlina
1966 Shasta Compact - 13' - sold
1966 Streamline Countess 26'
Old 12-13-2011, 02:17 PM
TPICherokee's Avatar
Sounds like an A/C unit...
Old 12-13-2011, 02:25 PM
I don't think it's an A/C system. There is no A/C compressor on the truck, and there are coolant lines that run to it.
Old 12-13-2011, 02:33 PM
asphaltrockdweller's Avatar
does it look like this?
If so it is a Mojave heater.
Old 12-13-2011, 03:41 PM
muddy's Avatar
muddy muddy is offline
The rest of the AC could have been removed by a PO. Or, I think it was on here, I remember reading something about someone converting their AC ducts into a heater to get more "in your face" heat, so to speek.
for reference, here's a pic of the stock AC ducts from a wagoneer,
(found on google)
http://t3.gstatic.com/images?q=tbn:A...utK6ALHGSwJ4US
1987 Grand Wagoneer,
well worn, bone stock, with 120K miles.
added a snow plow, and looking for a lift.
Old 12-13-2011, 03:42 PM
Hippie Metal Hippie Metal is offline
1984 GW T18/205
Originally Posted by TheDude
Garrett called me maybe 30 minutes ago with a blown tire, but knowing PBR is on the line not much can stop us
Old 12-13-2011, 08:38 PM
Alright, that picture answered my question. It must be the AC unit. Anyone have any use for the core and blower? The vents and ducting are ruined though...
Old 12-14-2011, 12:49 AM
Mark Wilde's Avatar
Mark Wilde Mark Wilde is offline
I've thought about converting my AC to a heater unit...but I don't want all that heat INSIDE the truck in summer....
90 Grand Wagoneer, 401/727/229, TFI upgrade, MC4350 4V, Edelbrock Performer cam, All-Aluminum Radiator, Razor Conversion, 4" Rusty's all-spring, 31x10.50 BFG TA/KO's...much planned, little time/money, thus she's a PipeDream!
Status: Up and running, but needs attention....
Old 12-14-2011, 01:12 PM
Next summer I'm putting a coolant shutoff valve in the heater line. Even with the heat off it still blows heat into the cabin. And after opening up the heater box I know why, when the flap is shut air still flows through the box, just not through the core. And the box gets heated by the core.
Old 12-14-2011, 05:42 PM
brushawg's Avatar
brushawg brushawg is offline
Ok, so what type of heater is a Mojave heater?
Just
Expect
Every
Problem
Got to love them
Heater Core Confusion catch2otwo General FSJ Tech 7 12-13-2011 07:34 PM
63-72 Heater Core Different Size? red mistress General FSJ Tech 15 01-07-2011 07:18 PM
Acid Core Or Rosin Core? vintagetrks General FSJ Discussion 7 01-18-2010 08:02 PM
replacing heater core only and/or assembly on firewall dutchman General FSJ Tech 18 12-24-2009 12:39 PM
Rebuilding a metal Gladiator era Heater Core Box w/ pix (tech) Gambler68 Other 11 09-09-2008 09:06 PM
