78 Wagoneer, Building a driver! New Thread.
  • Full Size Jeeper
    • Jul 20, 2014
    • 2475
    I mounted it to the left, but I might have to relocate it when we do the install on the after market air.
    1978 Wagoneer
    Mods:
    • Full Size Jeeper
      • Jul 20, 2014
      • 2475
      Went to a local speed shop today to pick up a few A.N. fittings I needed for the fuel system. It's in Independence Louisiana.
      1978 Wagoneer
      Mods:
      • Full Size Jeeper
        • Jul 20, 2014
        • 2475
        Also was able to get the pickup tube with the new fuel sock back in the tank. Installed the fuel pressure gauge and started running fuel line.
        1978 Wagoneer
        Mods:
        • Full Size Jeeper
          • Jul 20, 2014
          • 2475
          1978 Wagoneer
          Mods:
          • Full Size Jeeper
            • Jul 20, 2014
            • 2475
            Hope to have the tank, pump, and filters in tomorrow. Need to figure out where I'am going to mount all this stuff.
            1978 Wagoneer
            Mods:
            • Full Size Jeeper
              • Jul 20, 2014
              • 2475
              Also picked up these plug wire protectors, did I really need them....NOPE, but had to have them.
              1978 Wagoneer
              Mods:
              • Full Size Jeeper
                • Jul 20, 2014
                • 2475
                The exhaust guy could not fit me in so I made up a little test pipe. o2 has to be around 6 inches after the four pipes come together and you need about 18 inches of pipe after the sensor. Once I get it running I'll send it over to the exhaust shop. Hoping to have it running for the weekend. Fingers crossed!!!!
                1978 Wagoneer
                Mods:
                • Full Size Jeeper
                  • Jul 20, 2014
                  • 2475
                  (old sensor to protect the threads while welding in the bung.)
                  1978 Wagoneer
                  Mods:
                  • SOLSAKS
                    • Jul 25, 2016
                    • 1781
                    dang
                    more fine work from cajun country
                    we love this build
                    detailed and precise
                    I have those socks on my plug wires on a 69 charger with headman headers
                    I like them
                    and they have to be better for the boot to protect from heat,
                    as opposed to nothing.
                    dang fine wagoneer.
                    dave in NC
                    • Wagoneer Taylor
                      • Dec 17, 2018
                      • 434
                      Ill say it again, Inspiring build going on here! Awesome stuff, that thing is going to be loud as heck with those straight pipes!
                      Cant wait to see more!
                      Some call me Taylor...
                      Pewter, Blue Interior, Original 401
                      PO swapped in a 360, soon to be a 401 again!
                      "Soon" is a relative term.
                      Cracked cylinder put a hurt on me + bad connecting rods.
                      • rang-a-stang
                        • Oct 31, 2016
                        • 5512
                        After looking at a few other installs on this forum, I mounted mine above the trans cross member. I used electrical conduit brackets (they fit PERFECTLY around the pump with the insulating foam) and used rubber washers to isolate the brackets from the frame. When my pump is running (but the engine is not), I hear the swoosh of the fuel through the throttle body but do not hear the pump unless I am laying under my truck. The inlet of the fuel pump is about the half full mark on the fuel tank (I probably could have mounted it a little lower but didn't because I thought this was a good compromise between as low as possible to get siphoning out of the tank but upward to avoid smacking it on rocks/twigs). I used the existing wiring harness and conduit to run the power and ground line down to the pump. I installed my fuel pump relay on the firewall outboard the master cylinder. I am super happy with the install of my fuel pump so far.
                        ...I made up a little test pipe... Once I get it running I'll send it over to the exhaust shop. Hoping to have it running for the weekend. Fingers crossed!!!!
                        What?!?! Why?!? What's wrong with what you got there?! LOL! It's gonna sound like magic!!! Send us pics/vids/report on that first fire up! SOOOooo EXCITING!!!
                        Chuck McTruck 71 J4000
                        (Chuck McTruck Build Thread)
                        00 Baby Cherokee
                        • Full Size Jeeper
                          • Jul 20, 2014
                          • 2475
                          Ran all the fuel lines today. Lots of room around the trans tunnel, so that is where we put them.
                          1978 Wagoneer
                          Mods:
                          • Full Size Jeeper
                            • Jul 20, 2014
                            • 2475
                            Transmission tunnel back on.
                            1978 Wagoneer
                            Mods:
                            • Full Size Jeeper
                              • Jul 20, 2014
                              • 2475
                              Tank going back in.
                              1978 Wagoneer
                              Mods:
                              • Full Size Jeeper
                                • Jul 20, 2014
                                • 2475
                                Had to clamp the metal filler lines, had trouble getting the rubber lines on, this did the trick.
                                1978 Wagoneer
                                Mods:
