So I recently purchased my 80 cherokee laredo back from the owner I sold to 10 years ago. From what i could remember, it appeared most of it was stock until 78 Widetrac noticed it. I went out and crawled under the Jeep to see what i would see.
Rear Axle: it has a tag for 3.73 gears and paperwork in the dash for a detroit locker. On the lower right side of the center section, I see a 60 cast in it. It had drums and is 8 lug.
5352088 4-11 3.73
Front Axle:I could not find any identifying marks other than whats cast under the center section. I may need to be looking elsewhere. Here are photos of how it appears.
Transmission: I assume its the stock trans 4 speed. Again, I could not find clear identifying numbers on it. I did notice a Advanced adapters bellhousing adapter was used. Not sure what happened to the original. Parts number showing is 712569 70 11
Transfer case: Same as the trans. I do know the shifter is different from when I had it. I originally had the single shifter on the driver side. It now has twin sticks on the passenger side.
Any help on any of these components would be greatly appreciated.
5352088 4-11 3.73
