Old 12-26-2002, 02:24 PM
Merc69's Avatar
Merc69 Merc69 is offline
Question
The sheetmetal channel at the back of the Wag has collapsed. It was like this when I bought it. I have boxed the frame crossmember and reinforced it. When i bolted the body back into place I set a 14" section of 3/16"X2" bar stock inplace to reinforce this and when tightened the bar stock bent So I spent several hours scrounging around the metal dealers in the area and they all have metal way to big...2"X3"X1/4" angle. Overkill !!!
Any ideas?? I may have to go to a metal fab shop and have something bent to fit. There has to be a better solution...Help!!
Old 12-26-2002, 03:42 PM
Damage, Inc. Damage, Inc. is offline
Raybucks has channels like these...
If you need part numbers, PM me and I can look them up for you.
74 Cherokee
Old 12-26-2002, 03:49 PM
key's Avatar
key key is offline
Merc69,
These guys will have what you need ! Salvage yard with lots of Jeeps.
www.easternautomotive.net
Key<br />89 Grand Wagoneer<br />4\" SkyJacker Lift<br />Edelbrock Intake with 4 Barrel<br />33X12.5 on 10\" Wheels<br />Performance HEI Distributor and Wires<br />Roof Rack with Tire Carrier<br />ARB Bull Bar<br /><br />\"Yea though I fly through the valley of the shadow of death... I fear no evil ... for I fly the biggest, baddest, meanest, fastes
Old 12-27-2002, 12:37 AM
Merc69's Avatar
Thanks guys. I now have a couple of directions to try.
