Did the work up inside the dash today to run the harness and mount the ECM. I'd mocked up how I wanted to run the harness before, but I'll describe it better here. Since I chose to drill the 1.5" engine bay hole closer to the passenger side of the firewall, it allowed me to gently run the harness toward the steering wheel above the black HVAC ducting like the main factory waggy harness. The original waggy harness is closer in the pic with the clamp on it, and the ECM harness is behind it running toward the driver side on the left:
PXL_20210518_174751659 by Robert Stone, on Flickr
I then brought the ECM harness down and tucked it up inside the bottom lip of the dash, then continued running it along the inside of the dash till I curved it up back toward the inside flat part of the passenger dash:
PXL_20210518_174736992 by Robert Stone, on Flickr
Here it is tucked up inside where the HVAC assembly will keep it from dropping down into view:
PXL_20210518_174922149 by Robert Stone, on Flickr
Got the ECM mounted up along the inside flat part of the dash on the passenger side with massive velcro strips. Decided this would be the best location because of a few different reasons, much of it related to the size of the box!
A. The main harness in the cabin is very long and this mounting location made it easy to snake the harness around gently to avoid pinching or odd angles.
B. The ECM likely won't overheat with there being so much room.
C. There isn't much room to mount that massive box anywhere else that I liked.
In this pic the connectors are pointed toward the passenger side, driver side is toward the right. You can see the harness at the bottom of the pic coming up from the bottom of the dash lip where it won't get in the way of the HVAC assembly:
PXL_20210518_174816632 by Robert Stone, on Flickr
I got the A/C evaporator put back inside the HVAC assembly, then mounted the HVAC assembly, and now am pretty much done, except for eventual mounting of the OBD1 connector and the "check engine" light I still need to purchase.
Otherwise, I'll update this thread again later if something requires relocating or troubleshooting.
