Old 01-02-2018, 05:05 PM
DattMtn's Avatar
DattMtn DattMtn is offline
Adding Power Steering to a '74 Cherokee S w/258
I currently have a manual steer Cherokee S with the I6-258. What is the process for putting in PS for this motor? I have seen some threads where the response was "find a part out unit with the exact motor and same year with PS" and I don't find that a satisfactory solution as I don't have the time or resources to search through junkyards for these parts. And I am not going to dump money on a pump and steering box that may or may not work. Is there a resource of someone that has done this upgrade with new(ish) parts? Also looking for information before jumping feet first into this. Before lifting and putting larger tires it I want to do PS and a hydroboost brake system to make it more driveable as the bigger tires are going to negatively affect these attributes. Is used the only way to go? Does the steering box need to be off an old J20 or some other FSJ? I know BJ's has some parts but they appear to be RedHead and I've been told to stay away from them.
68 J2000 power steering conversion questions RKSNOW1 General FSJ Tech 3 01-10-2015 12:36 AM
AMC 327 power steering conversion?? 44BZ General FSJ Tech 3 02-26-2010 10:04 AM
Power steering pump OR Steering box??? HOOT General FSJ Tech 6 11-27-2009 10:52 PM
Power Steering 75 V.S. 81 round 2 Cherokee!!!! Lone Justice General FSJ Discussion 1 08-31-2007 05:13 PM
Need help with power steering KaiserMan General FSJ Tech 9 06-02-2006 10:49 AM
