Old 03-09-2004, 01:07 PM
The PIG Smith's Avatar
King Browless
I originally posted this on the Buick FSJ forum with no response, so I will try here.
I like Buicks.
I like Buick V8
I like Buick 350 V8
I like FSJ equipped with a Buick 350
I would like to own a modern FSJ with a vintage setup like a Buick 350.
So, I was thinking. (That always gets me into trouble)
A BOP Bellhousing is not difficult to locate.
I also am under the impression that a BOP Bellhousing would accept a NV4500.
So, if what I believe is true, that a BOP bellhousing will accept a NV4500 or even a NV3500,
then a 5 speed in a FSJ sounds like it would make a great swap!
The gas economy of the 5th gear and low first for crawling and towing. WhooHooo!!
Question:
1. Can a NV 5 speed bolt up to a BOP bellhousing?
2. If this pure fantasy on my part that a NV 5 Speed would bolt up to a BOP, then could it be adapted?
or the Bell welded or machined to accept a NV 5 Speed?
3. What rear end ratio would be best behind a 5 Speed? 3:73?
4. What transfer case would one for a passenger side drop? for a drivers side drop?
Bryan Smith
2017 Jeep Grand Cherokee Limited
- 75th Anniversary Edition - 1941 Trim Package - Recon Green
1986 Jeep J20
- Super clean rig from the AZ/CA state line
1982 Jeep J10
- Has become a Long Term Project.
1981 Jeep J20
- Commercial flat bed - Lost in a Divorce --gone
1987 Jeep J20 Pioneer
- Former Rick Bielec aka Ricbee plow rig. Major rust!! --gone
IFSJA Member #1933 Joined November 30, 2001
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 03-09-2004, 01:13 PM
testuser's Avatar
testuser testuser is offline
wow! Good post. I would love to puot a 5speed behind the Buick350 in my 70. In afct....I personally think it's the best FSJ motor.
However, I don't think that a NV4500 (or any relatives) will directly bolt up to a Buick350. I was under the imporession that 4500s were mainly used behind Ch*vy products and Dodg*s.
But I'm a moron so who knows.
AA doesn't list and Buick V8's so who knows...maybe they do bolt together.
http://eshop.advanceadapters.com/commerce/catalog/spcategory.jsp;jsessionid=A25BC239E28B2F0BF7491CBF 5A8CA7BC?category_id=1147&czuid=1078885927781
Old 03-09-2004, 01:17 PM
jode's Avatar
jode jode is offline
JB Welder
oooohhhh cooolll! Hope someone answers this one....
No FSJs for the time being - "I'm working on it, I'm working on it" (think Mike Meyers' SNL skit about the gut)
Old 03-09-2004, 01:23 PM
FSJeeper FSJeeper is offline
King of Unfinished Projects
For sure, the Buick 350 is the finest motor Jeep ever used. I have a ranch truck with a buick 350 and T-18 and it is awsome.
The NV4500 has a different, unique bolt pattern but the input shaft length, 6.5" is the same as Chevy. Seems like you would have to modify your bolt pattern and machine the bellhousing to accept the NV4500 input shaft retainer.
You would be much better off with a Ranger OD and T-18.
Old 03-09-2004, 01:35 PM
King Browless
Thanx.
If machining the input hole in the bellhousing and redrilling and tapping mounting bolt hole is all that is required, then I can have that done!
The input shaft length being the same helps.
Bryan Smith
1986 Jeep J20
1982 Jeep J10
1981 Jeep J20
Old 03-09-2004, 11:31 PM
King Browless
But to the top for more opinions on this topic.
Does the back of the NV4500 have the round bolt pattern that is common to NP style transfercases?
If so, the XCase choices are very broad! [img]smile.gif[/img]
Bryan Smith
1986 Jeep J20
1982 Jeep J10
1981 Jeep J20
Old 03-09-2004, 11:57 PM
Tonka J200's Avatar
Does anyone make a steel "scatter shield" style bellhousing for Buicks? It sure seems like you could find one, and that would be simple to modify for different transmissions.
-Frank
'63 J200 2WD
'63 J100 Panel Delivery
Old 03-10-2004, 12:28 AM
Mikel's Avatar
Mikel Mikel is offline
I know someone makes Chevy-BOP bellhousing adapters. Maybe you can use a NV4500 w/ Chevy bellhousing, and one of these adapters between the bellhousing and the engine. I think they are about $65
1969 M715 6x6
1963 J300 Swivel frame
Old 03-10-2004, 12:41 AM
King Browless
I agree!
Yes, Jegs sells a steel "scatter shield" style BOP bellhousing, but they are pricey!
Jegs: Lakewood Blowproof Bellhousings
Olds/Pontiac (which would include Buick)
620-15100 1965-77, All V8, (except diesels) $309.99
Bryan Smith
1986 Jeep J20
1982 Jeep J10
1981 Jeep J20
Old 03-10-2004, 01:01 AM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
360 AMC
The tailhousing on a NV4500 4x4 has the round NP pattern. Almost no stickout. The dodge version is indexed for the ford and dodge tcases and the chevy is indexed different for the chevy tcases. Ford and Dodge largely drop their tcases to the drivers side.
Old 03-10-2004, 01:18 AM
zmjeeps's Avatar
zmjeeps zmjeeps is offline
I made a spacer to go between a Dodge HD version of the NV4500 and a BOP Lakewood bellhousing. If I can figure out how to attach a pic here, I will. If not, see this link. http://home.supernet.com/~zmjeeps/FSJ.jeeps/long7.htm
At the very bottom of the page, you'll see the spacer, bellhousing, transmission and bolted to the engine.
Zack Heisey
Z&M Jeeps
419.893.4JEEP (4533)
www.zmjeeps.com
zack@zmjeeps.com
Old 03-10-2004, 01:19 AM
zmjeeps's Avatar
Should have noted, the engine pictured is a 500 caddy, but the bolt pattern is the same. The thickness of the adapter may have to change depending on the dimensions on the crank and pilot bushing.
Zack Heisey
Z&M Jeeps
www.zmjeeps.com
zack@zmjeeps.com
Old 03-10-2004, 01:58 AM
miked miked is offline
TCI makes that BOP->Chevy adapter, I have one, was ~$55 thru summit
http://www.tciauto.com/specialty/adapter_kits.htm
Chevrolet transmission to Buick, Oldsmobile, Pontiac engine: PN# 230001
[ March 10, 2004, 08:15 AM: Message edited by: miked ]
Mike D'Ambrogia - Sonora, CA
66 J2000 - "Speedy"
Buick 350-th400-D20-D44 front-D53 rear w/powr-lok front and rear
Do the Single Relay Headlight Wiring Upgrade for Early Jeep Wagoneers modification...
Old 12-23-2014, 10:13 AM
rockosocko's Avatar
rockosocko rockosocko is offline
Bryan. Digging up an old thread but..
Did you ever figure this out?
I also just picked up a 500 caddy motor/long tail 400 trans and did the usual googling searches and our site cam up.
I also have a NV4500 that was slated to go into a 77 step van for my business.
But now looking to sell the van and use the 81 Cherokee instead, and maybe the caddy/NV/14bolt/2wd instead of 4wd since I don't think I'd be using that any time soon.
Errol
