OK - to recap, I bought the Rusty's 2" Add-a-Leaf kit and installed the rears a week or so ago. Before starting the fronts (yesterday), I measured both sides from front wheel center to back wheel center and I am off ~1/2 inch. I'm thinking the rear passenger side is the problem as I had a hell of a time getting the center pin aligned on this side. In fact the center pin, while seated in the perch, is still slanted frontward quite a bit. So, I have to go back and fix that.
Here are some questions regarding the reinstall process of the spring pack and making it easy to align the center pin (asking again and being more specific this time). Each case below assumes the AAL has been installed in the spring pack with center pin tightened down.
Best approach to re-installing spring pack and aligning center pin is.......
1. Do I bolt in both ends of the spring pack at the eyelets first and then try to align the axel perch to the center pin? Then put U Bolts on? Because of the arch in the spring pack, I have found that this approach would require jacking up the spring pack and axel to the point where alignment is acheived.....a game of jacking and levering.
Or...
2. Do I bolt in one end of spring pack (if so which end?), then align the axel to the center pin and put on U Bolts? Then jack / block the whole thing to flatten the spring pack out so I can get the other end of the spring pack bolted in?
Or..
3. Do I align the axel to the center pin (spring pack ends unbolted and out of frame/shackles) and put U Bolts on.....then secure one end of the Spring pack (easy) and then jack /block the whole thing to get the other end in?
Please pick one of the above with tips or other suggestions. I'm sure everyone has different tricks, but perhaps one of the above is to be avoided. I used #2 when doing the back end (didn't want to drop gas tank to get to inner bolt)....maybe the problem?
Also, in a prior post someone suggested greasing the leafs to help with the re-install. If so, do I grease the entire length of each leaf or just the ends? I have bearing grease handy....can I use that? Finally, should I re-use the square pads (plastic I think) that were at the end of each leaf as part of the stock spring pack?.....many were busted up though. Do they help springs move on eachother?
Anything else?
I'm sure I am making this harder than it should be but those springs can be quite tough to work with......if you don't have the right approach
Thanks a lot.
Or...
Or..
Anything else?
Thanks a lot.
