Hi GW friends!
I posted a few weeks ago about overheating at idle. I finally grabbed a fan shroud from another member of a FB group, and purchased a new fan clutch from BJ’s. I don’t believe the lack of a fan shroud would consistently cause overheating into the red, so I took your suggestions about the clutch.
Installed both today, will drive soon, get it warmed up and idle to test very soon. In the mean time, I wanted to share this with you and get your opinion.
A few guys on FB noted that they think my fan might be backwards. I reinstalled as I pulled it and I thought it was the same in my manual. At the moment, the leading edge is the curved side, on the right and the fan spins clockwise, when looking at the jeep from the front. It’s pulling great airflow as far as I can tell. What do you think?
Also, someone pointed out the blades should partly be in the shroud...I’m guessing my radiator isn’t as thick as the original and therefor the shroud doesn’t come out as far. Is it useless in its current configuration? Maybe I need to get some spacers/washers and readjust to push the shroud out? Different fan clutch?
