Originally posted by SOLSAKS
Last weekend, I also adjusted the clutch and steering box. The clutch was essentially being depressed even with the pedal all the way out, probably my fault, so I adjusted it to factory spec. I also removed the steering gear play per the service manual. I still have about 10 degrees of play in either direction driving in a straight line, but that's a HUGE reduction from before. Clutch lets out much much smoother than it used to also.
Has anyone noticed that I've never mentioned the condition of the diffs? Well that's because I've been sticking my head in the sand about them. Time to crack open the old Spicer 44's and see what's what. I'm getting some seepage from the gaskets anyway, so they warrant replacing.
I've got a drivability question. The truck currently has 4.27 gears in it but and can cruise at a relatively comfortable 55-60 all day long it seems. Has some grunt to go faster, but the 230 just doesn't have the revrange for it. I've thought about getting some 3.54's to give me highway legs, but not sure if this would make it unbearable around town. Maybe a 3.91 would be a good compromise? Just trying to give the engine a breather when I take the highways and would also like to be able to take the occasional jaunt down the interstate...
