I currently have a stock 88 wagoneear and am in the process of swapping in axles from a j20 with 3.73's, a Dana 300 and will be running 33's or 35's depending on how much trimming is required with the 4" bds lift. I prefer a manual transmission so while it's all apart anyway I may as well swap the trans too. I'm leaning towards one of the manuals from behind an I6. The AX15, NV3550 or the 6-speed. All the posts I've read say you need to have the 4.0's flywheel balanced to match the 360's. Would I need to take a 360 flywheel to the shop or is there a spec they can match it to? It has also been mentioned that a spacer MAY be needed between the trans and the transfer case but I haven't seen it confirmed or denied. All input is greatly appreciated!
Manual Transmission Swap Questions
Since I'm going from auto to manual would they be able to use the flexplate to balance the new flywheel to or do I need to source a 360 flywheel? Can I use the pedal assembly from the donor rig (XJ,YJ, or TJ) or do I need an FSJ pedal set?'88 Wagoneer with an AMC 360, TF727
In the works: 4" BDS Lift, Dana 300, axles from a '76 J-20, Hydroboost...
Originally posted by CarnuckThey can use the 360 flexplate and balance the 6 cyl flywheel to match. You will need to use the 6 cyl starter too unless they are both the same style (solenoid coil on the starter).Jeff
'43 cj2a
'51 Willys p/u
'51 Willys Parkway Conversion
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
Originally posted by grimgauntI had to take both flywheels to the shop to balance the new one.
Yes, at least for jeep NP2xx transfer cases you need to have a 1/2 " spacer at minimum between the trans and the t-case (in my experience with a 219 and a 208)
ax15 definitely needs the spacer.'85 CJ7 Laredo- Rebuilt 360, Tuned Port Injection, T-176, D300, W/T 3.31 w/Trac Loc, 31x10.5x15 BFGs
Originally posted by grimgauntFind a FSJ pedal set from a manual tranny Cherokee or a J-truck and you will be set.'85 CJ7 Laredo- Rebuilt 360, Tuned Port Injection, T-176, D300, W/T 3.31 w/Trac Loc, 31x10.5x15 BFGs
Originally posted by jaberHis '88 will already have the XJ starter.Jeep gauges are for amusement only. Any correlation between them and reality is purely coincidental.
Originally posted by CarnuckI compared XJ pedals to FSJ and they don't come out right (middle of the brake booster)Last edited by ThisGuyUKnow; 03-12-2012, 05:21 PM.'85 CJ7 Laredo- Rebuilt 360, Tuned Port Injection, T-176, D300, W/T 3.31 w/Trac Loc, 31x10.5x15 BFGs
You dont need to ditch the vacuum booster to fit the clutch master.
I made a spacer for mine and had a longer rod installed in the booster.
k.89 Waggy
AX-15 swap info threads...
http://www.ifsja.org/forums/vb/showthread.php?t=83102
http://www.ifsja.org/forums/vb/showthread.php?t=97262
http://www.ifsja.org/forums/vb/showthread.php?t=104163
Theres more but that should get you started
Originally posted by JeepinPete-If it wasn't for bad luck, you wouldn't have any luck at all-
Originally posted by KrisYou dont need to ditch the vacuum booster to fit the clutch master.
k.'85 CJ7 Laredo- Rebuilt 360, Tuned Port Injection, T-176, D300, W/T 3.31 w/Trac Loc, 31x10.5x15 BFGs
dosnt the crank also need to have the hole for the pilot bushing?Abort? Retry? Ignore? >
Originally posted by ThisGuyUKnowAny specs on that spacer? I am glad you put your two cents in Kris when I have a convo with a shop or someone that tells me an ax15 or nv3550 cant hold up behind a 360 I always tell them about how your rig has held up for quite some time with one. Did you use stock FSJ clutch pedals modified to work with the clutch master? Did you use a master from a yj or something else?
Gimme a few and Ill link them.
Originally posted by Tripwiredosnt the crank also need to have the hole for the pilot bushing?
k.89 Waggy
