Holley sniper EFI 727 kickdown
  • J10 Bob
    • Jul 24, 2015
    • 2
    I have a 1983 J10 360/727 I just installed a Holley sniper EFI. I have a concern about the kickdown linkage. Holley tells me they only support GM transmissions (nice) The linkage on the sniper has two holes for the trans one for TH350 and one for 200R4/700R4. My concern is linkage travel. Do I need an adapter?
  • acct21
    • May 20, 2014
    • 735
    No adapter required — I just used a 1/4” threaded stud/lock washer/nut combo from Summit. Used the hole that best approximated the hole on the 2150.
    Downshifts perfectly; no issues at all. Didn’t have to adjust anything.
    Free Shipping - Summit Racing™ Carburetor Throttle Lever Studs with qualifying orders of $109. Shop Throttle Lever Studs at Summit Racing.
    • J10 Bob
      • Jul 24, 2015
      • 2
      Thank you
      Thanks man the info you provided is just what I need to hear.
      • pickledtoast
        • Feb 13, 2018
        • 59
        I'm actually taking a look at the same issue on mine this weekend. I initially set it to where it matched, but didn't really pay much attention to it. Now it shifts at ~3500 at WOT.
        • acct21
          • May 20, 2014
          • 735
          It wasn't an exact match. One hole sets it a bit forward, and the other a bit further back of the throttle plate axis. I'll look and verify which one I used.
          • Achilles
            • May 12, 2004
            • 1177
            Can you post a picture of how it is set up on yours?
            Life happens while you are making plans...............
            • pickledtoast
              • Feb 13, 2018
              • 59
              that is your email? I can forward a pic I took at lunch to you.
              • Achilles
                • May 12, 2004
                • 1177
                Sent it via PM
                • pickledtoast
                  • Feb 13, 2018
                  • 59
                  Replied.
                  • Achilles
                    • May 12, 2004
                    • 1177
                    Thanks for all your help!!
