SOA Steering Stabilizer Setups
Most state laws will not allow that type of modification. Is it off road only perhaps?1989 "KRONK"
Detroit front/rear 4.27 gears
Ramsey 9000 modified bronco winch bumper
Built 360/ 700r w/ 241c Lokar floor shifter
Hydro-boosted brakes
20" wheels w/ 35" Toyos
15" Welds w/35" Uncut mud boggers
Dual Ram Air /MSD TFI Ignition /Dakota Dash
www.fastfinishor.com
www.fastfinishor.blogspot.com
www.facebook.com/fastfinishor
Everything about this is wrong, even the cord on the light has exposed electrical wires. Somebody should delete the post. This is why offroading gets a bad wrap. A piece like this runs into head on traffic and kills someone. I am not one to criticize as we all have a learning curve but if you are on this site you can see excellent examples of fab work from many of us on this forum. Blake for example always posts nice examples of his work. You should be honest with yourself and realize you don't have the skills to do the work yourself and pay someone to do it for you or better yet, buy something that is already built and just go wheel it. Do us all a favor and take that thing to a shop and get it fixed right. You will probably just be better off to just trash the front end and buy something already set up for SOA, PLEASE!!!Aaron Womack
1978 Cherokee 360, 400/QT, HD44, Dana 60, 4.88's, locked, 36s on H1s, SOA/SF, high steer, Rancho RS5000's (14" front/11" rear travel) lots of dents
once the welds are ground down and everything painted Grabber Green, it'll be ok. Really.1979 Chero S "Sundog" 1979 Chero S "Hammer"
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Originally posted by Gambler68once the welds are ground down and everything painted Grabber Green, it'll be ok. Really.
That's what I do except mine's painted Hugger Orange to match my shock boots.
JR[quote] "How does someone from Iran have a BJ's Offroad sticker but I can't seem to get one sent to New Jersey???!!!"
1966 mustang fastback
'07 Dodge Charger 3.5
I think his timing chain is a bit loose too...Flint
Oh dear God...-Jonny B.
AMC 401 - Pro-Flo 4 EFI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Originally posted by BlakeSONORA POSSE
Buggy- EZ-EFI 401, 727, D300, 60's, 1.75" DOM chassis, 42" Sticky Iroks
Thanks! Interco Tire, Sierra Gear & Axle, Powertank, Raceline Wheels, HereticFab, & Reid Racing
'82 CJ-7- AMC 401 Edyl Heads, Forged pistons, NP435, D20, Waggy D44's, Spool/Detroit, 4.56's, 36" Irok's
'77 Chero- 360, T18, D20, D44, SF14B, 35" BFG AT's
I do appreciate you all keeping your comments civil. I saw the photos and was a little shocked myself. After scrolling through them reading the thread I just keep shaking my head.
Then I remembered that he has previously posted pics. It is an off road only rig and if I remember correctly you are going to swap out the blocks for the 4" springs?? The steering is still scary but it's good to know you trailer it to/from where you wheel. You might invest in some 5 point harnesses and a roll bar.
Flint... the timing chain joke was good... very funny!Last edited by will e; 11-25-2011, 02:38 PM.82 Cherokee WT ? SFwith Alcan/agr box/Borgeson shaft/ 401/performer/Holley TA/HEI/BeCool/727/ALTAS(2.0/2.72/5.44)/D60 Snofighter(Yukon Zip,hubs,stubs,4.56)/14 Bolt (FF,BF shave,Discs, ARB,Artec Truss)/MTR 37/Corbeau Moab Seats /Hella/tuffy console/sliders/custombumpers&roll bar/WARN 8000/steering brace/CO2 Tank/dual batts/custom TCskid plate
Originally posted by Mr.HappyfaceHere is how I did my SOA setup but I have high steer. I took the plate that was used to hold it from the factory and flatened it.
Blue 77 Wagoneer 401,Dana 44s,5.13 gears,spools,35 Boggers,12inch lift,offroader
Tan 77 Wagoneer 360 parts jeep.
Green 78 Wagoneer 360 parts jeep.
Originally posted by Mr.HappyfaceI a'm glad to see I provided you guys some Holiday entertainment. It does get towed to and from the park and is for Rockcrawling only.
Just keep it slow and I would personally avoid any significant hills. If one of those part snaps under load while you are pointed up/down hill you might find yourself going end over end or snaping a brake line and all heck breaking lose. You have added a lot of extra torque to places it wasn't designed to handle.82 Cherokee WT ? SFwith Alcan/agr box/Borgeson shaft/ 401/performer/Holley TA/HEI/BeCool/727/ALTAS(2.0/2.72/5.44)/D60 Snofighter(Yukon Zip,hubs,stubs,4.56)/14 Bolt (FF,BF shave,Discs, ARB,Artec Truss)/MTR 37/Corbeau Moab Seats /Hella/tuffy console/sliders/custombumpers&roll bar/WARN 8000/steering brace/CO2 Tank/dual batts/custom TCskid plate
Getting back to the question at hand, this is what I did. I cut and drilled a plate (5/16 I think) for a shock stud to mount on. This also served as a spcer to offset the height difference of the perches due to the casting on the drivers side. Later on I added a similare plate to the top of the drivers side for a second stabilizer.
401, NV4500, 3/4 ton gear
'79 Cherokee "The Sandgorgon"
One Tons, SOA,T18 on 40's
78 J10 "Imoteb"
J20 running gear and axles
