Maybe a jack in the box setup or can of snakes deal for the "curious" passenger
74 Chief Restore
Thanks Asada! I did end up shaving them down. Didn't get a pic yet but these are the same vents in the same dash, just no dash pad.
I met the glass guy at the shop this morning to get the glass installed. I wanted to get out there and drive the Jeep in this 100+ degree heat this weekend and see how it does. That and get the gauges programmed and all that. Well, someone broke the windshield. Glass guy says it wasn't broke when he took it out and blames my guy. My guy says he didn't break it and he and myself are the ones that moved it very carefully to the shelf it lived on while the dash was being installed. So you know what that means.....I get to buy a new windshield. Again.1974 Cherokee S. It's driving but needs more work. As usual!
This is an AWESOME build. There is a lot to learn from reading it.
Example.... (3 engine swaps). I had to stop and will start again tomorrow. Thanks for keeping it going.
BTW how is the sound deadener holding up that you put on the bottom of the roof? 2016 install date. I assume it's still sticking.
3 engine swaps. Sounds like I want to work on it more than drive it. Lol!
The sound deadener is holding up just fine. We had the cardboard head liner out a couple of weeks ago and that stuff is stuck permanently.
I haven't done a recent update only because there's no pics to share. But, the new windshield is back in and the repaired radio is back and going to be installed soon. I have other things in life going on so the poor Jeep is on the back burner again. I put my motor home up for sale and now have a list of "fixes" to do to get it prepared. A 3 gallon oil change is happening today.1974 Cherokee S. It's driving but needs more work. As usual!
Welp, We got the dash all bolted in, the gauges mostly wired and even got the windshield back in. The repaired radio showed back up on Monday and we finally had the time to get it in the dash and work on the wiring. Until.......
Yup! It won't go in all the way. Even adjusting the head unit to where it's sticking out of the bezel, it's still hitting the defrost ducts behind it. That's what I get for modifying the dash without it being in the vehicle. I think the game plan is going to be to heat the defrost ports and push them in about an inch. Well, if we can without breaking something first. Lol. There's always something.....1974 Cherokee S. It's driving but needs more work. As usual!
Why not make a shroud for it so it does stick out a bit!?
To me it doesn't look to bad.
I had the same issue with placing a car radio on another place in the dashboard of my j4000.Jeep "because mother nature hates flat roads to"
Former vehicles:
It's already sticking out as far as possible in that pic. Anything more would require cutting steel, repainting and what not. It should be easier to reshape the plastic. Hopefully.....1974 Cherokee S. It's driving but needs more work. As usual!
Don't force it. Just get a bigger hammer.Chuck McTruck 71 J4000
Maybe cut off a section? Then glue a flat part on ?
Maybe a little more controlled then heat.It's not yours 'til ya bleed on it . . . https://forums.ifsja.org/core/images...s/rolleyes.png
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
1972 J4000
2012 Artic JK 4 door, 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
You guys so funny! Lol.
I had forgotten those ports unscrew from the rest of the heater system. You can see it in the pics. I'm going to look into removing them and making something else. I just need to make sure there's clearance to the back of the radio and they don't get hit by the wiper linkage. Other than that, I should be able to make it work.
I've got stuff coming up though so this will have to wait until next week sometime....hopefully. We're refinancing the building the Jeep is parked in and because California, we now have to perform a Phase 2 Environmental test in the building and in the parking lot. That means the motorhome, trailer and everything else in the parking lot needs to disappear. Inside the building I have to shuffle stuff around to allow them room to come in and drill holes in the concrete to pull core samples. One of them holes is in the office so I gotta move a desk and pull the carpet up. I have to have all this prepped and ready to go by 7am Tuesday. I really hate California sometimes.1974 Cherokee S. It's driving but needs more work. As usual!
3 months later.....
We're starting to get back to the Jeep again. Finally. Made a new defroster duct outlet out of exhaust tubing. Started with a U shaped 2" tube and cut it to the desired angle and ended up welding an adapter going from 2" to 2.5". It took a lot of time to measure, cut, fix it, cut again and get the right angles. Fun. But it's done, the radio is pushed all the way in and lots of clearance to the radio and wiper linkage.
The air blows with a lot of volume so good enough!
Meanwhile, my manual tailgate window crank decided to stripe the splines and leave me with a non working window. So as the Jeep sat collecting dust, we decided to pull the spare tailgate with the electric window and cannibalize it for parts. That manual crank setup wasn't working all that great to begin with anyhow.
The Jeep didn't come with an electric window and I don't think it had the wiring harness anyhow. So, we decided to start from scratch. I went to BJ's to buy a bunch of parts and rebuild the tailgate again including the electric switch they sell for the tailgate. It's basically an aircraft toggle switch with an adapter to take place of the factory switch. This switch is rated for 10 amps and I figured I'd give it a shot without using relays. Yup, no relays. I'll add them later if the switches can't handle the load but I'm sure they'll work fine. "They" meaning there will be one in the dash too. So off I go with pen and paper, a VOM and battery to test and mock up the wiring on the bench before diving into the Jeep. Didn't take very long. Pretty straight forward stuff.
The dash switch has 3 terminals. Keyed 12V supply going in and 2 feed "up and down" wires running to the tailgate switch. Also running to the tail gate switch is a hot 12V wire so 3 wires running to the tailgate switch total. The tailgate switch has 6 terminals btw and acts as a terminal block. The power from the front two wires feed through the rear switch and to the motor at all times. When you activate the rear switch, you're pulling power from hot 12V feed and sending the power to the motor. Make sense? I know, clear as mud.
Basically, the front switch needs the key on to roll the window up and down. Using the key in the tailgate does not require the key to be on.1974 Cherokee S. It's driving but needs more work. As usual!
