Went to start the truck today and I can't get it to fire. I checked the distributor, it has good spark. The carb is allowing gas to flow fine, however when I pull the plugs to do a compression test (135 lbs) the plugs are completely dry, no fuel on them what so ever. The timing appears to be correct, and is not 180* out. When I removed the carb and plugged the hole with my hand, I can feel the air moving. I'm stumped and looking for insight.
Truck has been running perfectly lately, and does not diesel, etc which would raise concerns a out the timing jumping. The engine is a rebuild with about 2000 miles on it. Hei distributor and motorcraft 2150 carb.
