What is the gasket that goes behind where the oil filter screws on called and do they sell them or will I have to make one?
Thanks.
84 Grand Wagoneer 360/727/208 Gobs of lift 35" pro comp x at
03 Jeep Liberty 6 cyl..whatever....but it gets a
little better mileage.
92 Dodge van to live in when my Jeep costs me so much I lose my house.
Now is agood time to install a Bulltear mid plate and select fit the gasket that will give you the proper gear to cover clearance.
1985 J-20 401 6 inch lift, 37's plow truck. CURRENT PROJECT
1986 CJ 7 360 T-18 granny low Dana 44 , 4 inch lift 35's
1882 CJ 7 360 727 auto Dana 60's 35's cage
1970 AMX was SCCA B production. 390 cross ram. GOOGLE IT
Thanks. 2 auto parts stores said they showed nothing. Would it be included in a gasket set for the whole engine? I'm considering new water pump, new timing chain and gears, and all new gaskets.
