Question about a 79 cherokee (looks to be a cheif)(d300 question)
  • malodin
    • Sep 03, 2004
    • 1527
    Ive got a chance to buy a 1979 cherokee, white/with black trim, looks like its got fender flares so i imagine its a w/t the guy says its got a 258/4spd with a dana 300.
    My question is this an actual dana 300
    and what gear ratio do you think the axles are?
    [ September 01, 2005, 10:35 PM: Message edited by: malodin ]
  • Green Giant
    360 AMC
    • Jul 31, 2001
    • 2896
    Should be a Dana 20 and 3.54 gears more than likely.
    Todd Moon
    78 Cherokee Chief
    78 Chief
    66 J-3600
    69 J-3500
    67 CJ-5
    67 J-100 w/BARN DOORS
    48 CJ2-A
    Proud member of Carolina Full Size Jeep Club
    cfsjc.com
    No part of this post, written or pictured, may be re-used by any individual or organization or publication without my express written permission.
    (Thanks, Flint!)
    • Green Giant
      360 AMC
      • Jul 31, 2001
      • 2896
      'Course 79-80 was a changeover year, so could be a NP208. Or something else could have been swapped in.
      The D44 should have a tag with the ratio on the cover bolts and the AMC 20 (round cover) would have a code number stamped into it.
      Todd Moon
      78 Cherokee Chief
      78 Chief
      66 J-3600
      69 J-3500
      67 CJ-5
      48 CJ2-A
      cfsjc.com
      (Thanks, Flint!)
      • malodin
        • Sep 03, 2004
        • 1527
        i dont think its got a amc20, my 77 cheif is dual d44's with the qt.
        [ September 01, 2005, 10:04 PM: Message edited by: malodin ]
        • jeepguzzi
          • Oct 21, 2000
          • 4027
          It should be a Dana 20 transfer case.
          If you are buying this to part out, I would like to call "dibs" on the steering wheel!!
          [ August 24, 2005, 12:31 PM: Message edited by: jeepguzzi ]
          • Green Giant
            360 AMC
            • Jul 31, 2001
            • 2896
            jeepguzzi, sent you a pm
            Todd Moon
            78 Cherokee Chief
            78 Chief
            66 J-3600
            69 J-3500
            67 CJ-5
            48 CJ2-A
            cfsjc.com
            (Thanks, Flint!)
            • fixit
              • Jun 21, 2005
              • 20
              what side is your front diff on ? i have the 208 with my 258 and 5 spd
              broke q-traq looking for a good up grade <br /><br /> always looking for the next adventure
              • mdill9
                • Sep 21, 2004
                • 772
                One possablity, however remote, is that someone
                in the know and hard core enough did a 80 Scout
                D-300 swap. (1980 Scouts had a texas pattern D300
                same as the D-20 case) They are pretty rare given
                it was the last year the Scout was produced.
                Mike D.
                • tgreese
                  • May 29, 2003
                  • 11682
                  Look at the type of metal the output housing of the transfer case is made of. Iron = Dana 20, aluminum = Dana 300.
                  The texas-pattern 300 is pretty scarce; if you have one, it's worth more than the whole truck.
                  • malodin
                    • Sep 03, 2004
                    • 1527
                    thanks for all your help guys i think i might get it.
                    • malodin
                      • Sep 03, 2004
                      • 1527
                      i will probably part most of it out.
                      • JEEPDUDE
                        • Jan 31, 2004
                        • 270
                        I would be up for the complete steering colume . I am going to a floor shift and would like a colume without the auto shifter.
                        • malodin
                          • Sep 03, 2004
                          • 1527
                          if i get it you got first dibs jeep dude
                          • malodin
                            • Sep 03, 2004
                            • 1527
                            ok so back to top cause i got a new question, i talked to the guy and he sent me a pic of the tcase, it is a d300 and he said if he remembers right the tcase was already in the rig when he got it, and he sourced out a tranny for it from a cj style jeep. so my question is, ive got the th400/dana 20 setup from another rig, if this d300 is a cj style d300 will it still bolt up to the d20 style adapter? in other words, can i still pull the th400/d20 adapter out of my xtra tranny and install it in my th400 w/qt and hook up my d300 to it?
                            here is a pic of the tcase
                            • tgreese
                              • May 29, 2003
                              • 11682
                              The Jeep D300 uses the circular New Process pattern and is not compatible with earlier transmissions without an aftermarket adapter. The Jeep D20 is the so-called "texas" pattern; not compatible with the NP pattern. So, nothing here is compatible. The TH400/QT is unique, and the Jeep D20 and D300 are different.
