  #41
Old 03-10-2008, 08:24 AM
hull1962's Avatar
hull1962 hull1962 is offline
CARLOS ALVAREZ
Jeep Gladiator Super V 66 " La Santa Matrakita"
www.clubjeepgladiator.com.ar
Old 02-03-2010, 08:43 AM
mike12's Avatar
mike12 mike12 is offline
lights
i thank grantshire is on to sumthing mike 12
Old 02-06-2010, 08:21 AM
madmikeX3's Avatar
madmikeX3 madmikeX3 is offline
I agree grantshire should Post up a How-to
Just Empty Every Pocket
US ARMY
1980 Jeep Cherokee W/T
“Nice Jeep Bro!!!! Do some Jeep Stuff!!!!.”
Old 02-06-2010, 12:43 PM
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Originally Posted by hull1962
slick, it would be tough finding those parts in the US
DDs
67 KJ715 4bt AA OD 465 np205
78 J20 Chevy 305 nv4500 np205
Projects
Sons Build 1980 short bed J10, j20 axles, 4bt, nv4500, np205, shortened M715 bed and fenders
Freedom is not Free, it is paid for with Blood
Old 03-17-2010, 01:54 AM
homerj40's Avatar
homerj40 homerj40 is offline
OEM dual headlight setup
I have seen the OEM dual headlight setups in original sales brochures.
I lucked out when a complete Rhino Grill setup showed up on eBay with the DUAL LIGHT SETUP. Picked up the whole kit for $150 + $50 shipping. I already had the Rhino grill on my truck so I kept the lights and sold the grill and outer lights with my pie tins for more than I paid.
Here are pics (couldn't get the upload to work)
http://gallery.me.com/syncthis#100058
The inner lights are standard 5.75" size used in 50's and 60's dual headlight setups on most cars. My housings had 1 1/2" lobe extensions at the 9 & 12 o'clock positions that accommodate the adjustment screws. I had to break away two tabs that are spot welded into those positions in the pie tin holes and the housings screwed right in. As you can see, the bezels match the outer lights perfectly. These were a dealer option but it seems like not many people ordered them. Since they are based on a standard headlight part I bet that they are fairly standard to most dual headlight setups. A little junkyard trawling should turn up the housings. The bezels might be a hit-or-miss affair.
Hope this helps any body trying to make an original looking setup. Good luck!
"Simpson you boob, you've destroyed us all!"
'69 J2000 Gladiator (Grover)
Buick 350, F.A.S.T. 4bbl EFI, TA Stage 1 manifold, ported intakes, roller rockers, Voodoo cam, full length headers, Early Bronco COIL SPRING FRONT SUSPENSION, 700R4 trans, D20 twin stick, hydroboost, front discs, A/C
Mine's a Hybrid - It burns gas AND rubber!
Old 03-17-2010, 05:54 AM
Homer - I am convinced... You have a beautiful Gladiator!
Old 03-17-2010, 08:52 AM
X2. I LOVE that color...
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 p/u
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 03-17-2010, 12:03 PM
homerj40's Avatar
Thank you. I've had my eye out for a truck like this for a long time.
My 1st was a '67 J2000 w/230 Tornado that I never could get running. (That was 34 YEARS AGO)
The color is 2000 model year Chysler "Patriot Blue Pearl"
(I think it came on Jeep Liberty's)
Old 03-17-2010, 07:01 PM
Gutter's Avatar
Gutter Gutter is offline
If theres a 'Rick out there reading this that contacted me about rings, your
return email was no good.
Sorry for the hi-jack, move along.....nothing to see........
.....Wish it was a Hilfiger Edition.....
Old 03-17-2010, 07:58 PM
Long&Low's Avatar
Long&Low Long&Low is offline
That has me sold, my next one is gonna be blue.
Very nice truck.
Breakfast amounts to one live toad, I choke that mofo down, and I am rest assured that nothing worse will happen to me for the rest of the day.
___________________________
'68 CJ5
'92 YJ
'06 Commander
Old 03-18-2010, 09:43 PM
homerj40's Avatar
I just posted new pics:
http://gallery.me.com/syncthis/100058
Old 03-18-2010, 11:05 PM
shackwrrr's Avatar
hard to see with the razor but I have boobie turn signals in aluminum plates behind the razor. With white bulbs they are acually pretty bright
Jeepless
In to Turbo crap now
Old 10-08-2011, 10:05 AM
serehill serehill is offline
Gone,Never Forgotten.
X2 On the Homers Gladiator.
I picked my color because I hadn't seen one this color. I should have known. It is an awesome truck & color.
Old school is cool there's a million ways to the the pie lights. That with the panel conversion took mine way back & modern.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 05-15-2017, 05:07 PM
scramboleer's Avatar
scramboleer scramboleer is offline
Noob!
The (a?) previous owner added the second set of lights to my '66 J3000:
1966 J3000 Gladiator
1982 CJ8 Scrambler
Old 05-16-2017, 08:29 AM
66Stepside's Avatar
66Stepside 66Stepside is offline
Here's my set up using separate aircraft landing spotlights. I did a simple how-to video for a single wire hook up to a toggle switch. I've since swapped over to Amber fog lights in order to avoid blinding everyone with the spot light bulbs.
66 J3000 Thriftside
62 J200 Father/Son Project
67 Yellow 1414D sold
67 White Basket Case 1414D
68 White 1414D
Old 09-22-2017, 07:40 PM
RuidosoKid RuidosoKid is offline
Noob!
Hi Dennis,
So what did you use for the plate that goes behind the bucket and screws into the support. Unfortunately the mustang had the whole section as one piece so can't use that..? I appreciate you listing all the parts needed and part numbers as I am working on tracking those down as well...
- A.J.
Originally Posted by zinertia
Parts list to add two 5 3/4 lights in addition to the two 7 inch lights you already have, if you have a Rhino Grill
These parts are from California Muscle Parts (Mustang) but they can be found at all of the early Mustang places
Headlight Bulb Bucket 1969 13118D (RH) - 1 req'd
Headlight Bulb Bucket 1969 13118E (LH) - 1 req'd
Headlight Bulb Retaining Ring 1969 13015B - 2 req'd
Headlight Bulb Adjusting Screw 1969 13033C - 4 req'd
Headlight rings 3100235 from J&P Cycles - 2 req'd
(these are the least expensive rings I could find, the billet ones are $$$$)
two 5 3/4 inch headlights of your choice, I have two HLA - 0002425831 from Summit - they are upgrade lamps but are not DOT approved (not cheap!)
The only thing left are the two springs to hold the headlight buckets in as well as the "behind the bucket" mounts that I will be either looking for or fabbing up
Dennis
