Old 02-27-2008, 07:27 AM
The PIG Smith's Avatar
King Browless
Dual Round Headlight Rhino setup
I was saw this and starting thinking.
Instead of a single round headlight and faux cover with the Rhino Grill, how about a dual round headlight assembly from a big rig?
There is also dual square headlights, but IMHO they would not look the best with a Rhino Grill.
USE HEADLIGHTS FROM THIS:
ON SOMETHING LIKE THIS:
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 02-27-2008, 07:34 AM
chrisnsarah's Avatar
If you look in the book "JEEP-The Unstoppable Legend", You'll see a clay model of a wag in the design stage with the exact setup you're talking about.
Sorry, I'll have to scan the pic unless someone has an online link.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 02-27-2008, 07:36 AM
cajun_lad's Avatar
cajun_lad cajun_lad is offline
Nah... just get some offroad rounds that are the same size as the faux vents and run 4 lights that way. The molding around the 2 'light' holes is different cause of the 2 different size holes. I don't think you could make that dual headlight assembly fit and look like it's supposed to be there. But if you think you can, go for it... and then post pics.
Joey
Jeep-Less
Old 02-27-2008, 07:42 AM
Yea, the clay prototype looked real funky IMO . I'm glad the designers went to the current setup.
'64 J200 thriftside
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
Old 02-27-2008, 07:53 AM
King Browless
Yes, I saw that.
The core support/head panel (what is the correct name for this?) starting at the the top and going down, is slanted, the bottom is slightly inboard than the top is. (did I say that correctly?
So, a person would need to cut the part of the panel with the headlight hole and faux cover hole out and replace it with a panel that would accept the new dual big rig light assembly.
I do not think this would be a big deal.
Bryan Smith
Old 02-27-2008, 08:26 AM
mdill's Avatar
mdill mdill is offline
I remember one of the members put a DOT standard small high beam using buckets and trim rings from an early american(??) car that had the dual small headlights. Now for the life of me I don't remeber what the make/model of the car was.
So to the group what car had dual small rounds with separate trim rings ?
Mike D.
Old 02-27-2008, 09:16 AM
cajun_lad's Avatar
Just curious, but do the CJ smaller parking lamps fit? Wonder how close it is? Knowing Jeep, I bet they are similar in size for "universal" use.
Joey
Jeep-Less
Old 02-27-2008, 09:40 AM
Gil's Avatar
Gil Gil is offline
That's what I would do (if I didn't have other issues to contend with first).
Gil
1980 Cherokee Chief
Old 02-27-2008, 10:01 AM
Long&Low's Avatar
Long&Low Long&Low is offline
Go for it!
Breakfast amounts to one live toad, I choke that mofo down, and I am rest assured that nothing worse will happen to me for the rest of the day.
___________________________
'68 CJ5
'92 YJ
'06 Commander
Old 02-27-2008, 10:23 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
For some reason I think Visacha (sp?) did that one his. There have been a few threads about dual sets of lights with the Rhino setup. I think they used Lincoln Continental lights, Saab lights and a few others that were the right size.
BJ's Off-Road
ryan@bjsoffroad.com
Old 02-27-2008, 10:24 AM
Mike D.
I'm not sure either, but you can try a '63 Chrysler Imperial Lebaron. I can't remember the cutoff year, but there was a "married" and "divorced" headlight ring setup.
Want a real headache ? Look for the inner ring from a Chrysler turbine .
'64 J200 thriftside
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
Old 02-27-2008, 10:34 AM
King Browless
Yes, I've seen threads about folks that have replaced the faux cover with some other type of lighting.
I was thinking someone used a headlight assembly from a older Mercedes and it fit in the faux hole with little trouble.
BUT...this thread is about the opinions of how good or silly the entire dual round headlight assembly from a large truck would look on the face of a FSJ.
I am thinking it would give a FSJ a serious attitude look, especially with a lift kit and larger tires.
Most of these dual round headlight assembly from a large truck are very generic.
They were used on both conventional and cab-over rigs.
The nice thing about these lights, they mount to a flat surface.
On the tilt noses, those are fiberglass, so these means the lights must have a separate ground...another good feature.
While I have not found a source for them yet, but they must be zillions of them around in both round and square configurations.
AFAIK, these light assemblies are not manufacture specific and could be found on just about any make/model big rig.
Bryan Smith
Old 02-27-2008, 10:48 AM
If you really do go for your original idea, you can cut out the sheetmetal section with the stamped headlight and faux grill and weld in a flat piece of metal. Then cut the opening to accept the dual headlight. It would be best to find one that mounts on a sloping surface to match the angle of the valence.
'64 J200 thriftside
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
Old 02-27-2008, 11:05 AM
cajun_lad's Avatar
Let me see.....
Joey
Jeep-Less
Old 02-27-2008, 11:14 AM
red mistress's Avatar
Pie Plate to light swap
I am interested in installing some bright driving lights in the faux vent covers as well.
I can't stand anything "fake" even if factory intended.
There was alot of talk and pictures thread "pie plates" and I've searched but can't find.
Vascuez (sp) couldn't find member, did KC slimlites with some sort of trim ring that looked pretty good from the avatar picture I remember.
I've sent email to http://unityusa.com/Revised%20New%20...D%20LIGHTS.htm
But they don't have any surface mount lights, although they will build special order lights. At $500 each, I passed, hoping that I could find some junkyard car lights that would fit, but I don't go junkin enough.
I've even searched marine lighting as I've seen offshore boats that have flush mounted lights into fiberglass, but 1 billion hits come up. Motorcycle lights and same thing too many hits.
69 Jeepster 8701 convertible
80 Honcho Sportside
82 CJ-8 75K org SR decals
82 Cheroeke Laredo 24K
84 CJ-8 mud Scrambler
Old 02-27-2008, 11:17 AM
Grantshire's Avatar
Grantshire Grantshire is offline
You mean llike this?
Nah...can't be done!
Richard
62 Willys SW
66 CJ6
67 M715
69 C101 Commando
74 Wagoneer Custom
79 WT Cherokee Chief
81 Scrambler
86 CJ10A
Old 02-27-2008, 11:18 AM
Geeeep's Avatar
Geeeep Geeeep is offline
Check out http://www.ifsja.org/forums/vb/showthread.php?t=10501 gbarrett's post. Mercedes 300 lights, then you could upgrade the bulbs most likely.
Dave Pitts, located directly over the center of the earth!
GW - 87 GW 360/4bbl/727/208 Vinyl floor, manual windows, no woodgrain
Find someone to haul your Jeep here: YT Hauling Schedule
Old 02-27-2008, 11:21 AM
King Browless
Let me see.....
YESS!
Thank You!
Part of me kinda likes it, another part goes...Nahhhhh
Bryan Smith
Old 02-27-2008, 11:22 AM
Geeeep's Avatar
One light, two lights. Where does it stop Next you have so many lights hanging off the front you'll look like one of those mod scooters ala Quadrophenia
Old 02-27-2008, 11:31 AM
cajun_lad's Avatar
what about some of these?
http://cgi.ebay.com/ebaymotors/MERCEDES-108-109-111-250-280-300-SE-SEL-6-3-HEAD-LIGHTS_W0QQitemZ330214745709QQcmdZViewItem?hash=it em330214745709
Joey
Jeep-Less
