Old 09-22-2017, 02:35 PM
How far can we extend our front Quadratrack Drive shafts?
I am putting the final touches on my Front Shackle Reversal but my driveshaft seems to be too short when I am at full droop. I have stock springs but the reversal kit lifts the truck about 2.5" and moves the axle forward about an inch according to RockLaurence (which seems about right so far).
I guess my question looks like this: When I extend my driveshaft, it seems to slide smoothly then stop. Is this stop a hard stop or is it maybe just contamination on the splines inside the shaft because it has never been extended this much? In order to position my axle correctly I had remove my driveshaft from the yoke. I have my axle in now but I cannot extend my shaft enough to meet the yoke (at full droop). I am not sure if I should just yank on the driveshaft and see if I can get a couple more inches out of it or should I remove it and go have a new one made (really don't want to...).
79 Cherokee Chief Wide Track, In pieces
Old 09-22-2017, 03:29 PM
Mikel's Avatar
Mikel Mikel is offline
I would try to have a spline engagement at least 1.5 times the diameter of the splines.
1969 M715 6x6
1963 J300 Swivel frame
Old 09-22-2017, 03:59 PM
Should I be able to just pull it apart? I have no idea how much spline engagement I have...
Old 09-23-2017, 10:18 AM
wiley-moeracing wiley-moeracing is online now
Your going to need to have your driveshaft rebuilt with long spline shaft when converting to a shackle reversal system. if you don;t and the shaft comes apart you will punch that transfercase out the back
Old 09-23-2017, 12:00 PM
sigh. That's what I thought.
Do you have an extra one from the rig you parting out by any chance, Wiley-Moe?
Old 09-24-2017, 07:28 PM
J20 project's Avatar
shaft
You are running the back of your spline section into the interior of the seal section, hence,,,,no more extension.
Being a 1.25 in shaft you are somewhat limited in options...however, a long travel 1.375X16 spline is available for the 1.25in shaft. Coupled w/ a new long travel slip yoke...and those items installed into your shaft....bingo. Good to go.
Couple other things to think about. Your shaft needs to be dis assembled, double cardan section rebuilt, spline installed and then have the entire shaft balanced in the process. Especially true that the balance be good due to you running the Qtrack case.
I built a long travel 1.25 X .188 wall shaft for a buggy the other day...beefy for a small shaft.
I can do this work, any competent d shaft shop can do this work, Tom Woods can do it. Just a matter of who you want to spend your money with..
Good luck,
J20 project
BP Drivetrain...........
775-537-7918
Old 09-25-2017, 12:24 AM
OK, copy that. I have a spare front QTrack driveshaft in my garage. How much should I expect to pay a shop to: dis assemble, rebuild the double cardan section, install the long travel slip yoke/spline and then balance the shaft?
I don't know if I am looking at $100 or $700. Google told me there are quite a few shops around me but I don't know how to speak "driveshaft" enough so I only order what I need and don't get talked into something I don't. Are there steps I can do myself to save some $$ or parts I can buy that may be cheaper for me?
Old 09-25-2017, 07:07 AM
bkilby's Avatar
bkilby bkilby is offline
I'll send you an email later rang. I have a couple of DS contacts that will help.
Old 09-25-2017, 11:00 AM
expect around 500 plus for a shaft upgrade, last one I did for the race truck was 575 for long splines, high angle joints, good u-joints. That was a lot of years ago though.
Old 09-25-2017, 02:37 PM
Hey J20 project, trying to send you another PM but it says your inbox is full...
Old 09-26-2017, 12:47 PM
cleaned some out...didn't realize
J20
775-537-7918
no front wheel drive? djmac Off-Road FSJ Tech 7 01-18-2010 05:40 PM
question about front drive shaft Chief Gunner General FSJ Tech 0 12-12-2009 11:10 PM
front drive shaft 82lerado General FSJ Tech 1 12-08-2009 12:44 AM
Front Axle shafts olin18 General FSJ Tech 6 03-28-2003 01:45 PM
NP229/Dana44/Front Axle Disconnect...Scottie? Joe Guilbeau General FSJ Tech 8 03-06-2003 11:44 PM
