Donor High Back Seats?
  • topcat_92
    • Aug 07, 2017
    • 27
    Any suggestions for donor seats with a higher back/headrest for a Chief?
    Also, my over-the-shoulder seat belts won't retract at the waist. Is this repairable or should I look for a replacement?
    Thanks.
    topcat_92/Scott
    Seattle
    '86 Grand Wagoneer
    '78 Cherokee 401 Levi
    ex-'79 Cherokee
    ex-'76 CJ-5
    ex-'76 J-10
    ex-'78 Cherokee
  • wiley-moeracing
    • Feb 15, 2010
    • 1430
    Dakota seats work good and try pulling seat belts out and cleaning them in a bucket of soapy water and scrub brush
    • 8man
      • Jan 04, 2011
      • 1561
      I used the second row set from a Honda Odyssey, including the arm rest. Go the last page of my thread and you can see the install.
      • RamJetFSJ
        • Jul 18, 2001
        • 896
        I also have heard the Dakota/Durango seats work well and are an easy swap. I loved my Dakota (and its seats), so Ill probably try them, even though I really would rather have low back seats. The Dakota extended cab seats fold forward for rear access on the Cherokees also.
        Ben
        1980 Wagoneer - Ram Jet 350, 700R4, NP208, 4" lift, 33x10.5 tires.
        • topcat_92
          • Aug 07, 2017
          • 27
          Thanks for the feedback. I'll do some looking around.
          topcat_92/Scott
          Seattle
          '86 Grand Wagoneer
          ex-'79 Cherokee
          ex-'76 CJ-5
          ex-'76 J-10
          ex-'78 Cherokee
          • asphaltrockdweller
            • Jul 09, 2009
            • 1218
            I have the Dodge Dakota seats in my waggy.
            Up to 2001 I believe are a direct bolt in. All you need to do is bolt the seat tracks from your buckets to the Dakota seats.
            If you are going to a junk yard looking for them, make sure you get the seats, and the bolts for the tracks.
            The Dakota seats are metric threads, and your FSJ seats use SAE.
            OH!
            Also make sure you look for the two door Dakota's, as some of the crew cab trucks seats will not tilt forward.
            (Ristow)fram!....that deserves a ratchet upside the head.
            • RamJetFSJ
              • Jul 18, 2001
              • 896
              You can get the Dakota seats with a matching center jump seat too, in the 40/20/40 split "bench". Not sure how bolt in that setup would be though.
              Ben
              • kansasboy001
                • Nov 06, 2016
                • 163
                2000-2005 pt cruiser seats bolt right in with a little modification.
                1983 Cherokee Laredo. 360/ 727/ np228/ Junkyard 7427 TBI/ Msd ignition
                • fulsizjeep
                  • Aug 21, 2002
                  • 22496
                  95ish Mustang
                  The sliders bolt right up at the rear. Two holes to drill at the front.
                  • Driftwood
                    • Jun 12, 2000
                    • 959
                    Seats from 1997 Dodge Dakota Extended Cab worked for me. direct bolt in.
                    The link....Dodge Dakota Extended Cab Seat Installation
                    1979 Wagoneer
                    • topcat_92
                      • Aug 07, 2017
                      • 27
                      Thanks for the link to your install.
                      topcat_92/Scott
                      Seattle
                      '86 Grand Wagoneer
                      ex-'79 Cherokee
                      ex-'76 CJ-5
                      ex-'76 J-10
                      ex-'78 Cherokee
