Originally Posted by trail mule
I did a spring over om my wagoneer, and put a 4 inch block and a 2 inch block on top of that on the rear so that it would be level to the front  . No lift blocks on the front just the rear. I know that wasn't very wise but I am on a budget and I built a traction bar for it. That is why I am coming here for help. Since I am on a budget I wanted to see if any one here had ever made there own leaf spring pack to gain a lift of about 6 inches, this would be for the rear to eliminate the lift blocks.
Shakle flip again is the only answer to your problem in my case still needed a 1" block to level it, but I went with a 2" which got it level when truck is loaded for a trip.
The cost is $0 for you since you already have a 2" block and the shackle flip is just about unbolting one side of the shakle and fliping it up and bolting it.
Making a spring that is 6" higher will make it so stiff it's not a spring anymore.
