Old 12-30-2008, 09:40 AM
4x4fEvEr's Avatar
4x4fEvEr 4x4fEvEr is offline
Shacle Reversal
This desrves its own thread.
Who's got one?
My reason for wanting one is to help keep my front springs from bending. As you know a reversal pushes the axle back as u hit an obstacle and standard shackles push forward which with he tires pushin too equals a lot of stress on the rear of the springs. So good idea to do it right?
I'm ruunin stock springs with AAL right now does that net the same lift as shackles forward?
I need some input
Old 12-30-2008, 10:07 AM
4x4fEvEr's Avatar
Ok trasborgs article says it keeps the leaves from bending but for rockcrawling leave em forward, but Cappa did it to hotdog hmmmm
Old 12-30-2008, 10:29 AM
j20brett's Avatar
j20brett j20brett is offline
The only reason to leave them forward is that it forces the leaves into the obstacle, instead of away, making it easier to climb. But the advantage of not bending leaves anymore far outweighs a small climbing advantage.
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-spooled hp60/detroit 14blt w/5.13's - 42's/CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 12-30-2008, 11:12 AM
4x4fEvEr's Avatar
This is true. I'm finding all kinds of articles for them but none apply to fsj's
Old 12-30-2008, 11:25 AM
Our 76 Waggy with SOA has the front shackles reversed and it flexes like an Olympic gymnast. It was set up this way when we got it so I am not sure what all was done in the reversal process.
Old 12-30-2008, 11:29 AM
Long&Low's Avatar
Long&Low Long&Low is offline
I ran a shackle reversal on my YJ. It allows the spring and axle to climb stepped obstacles better.
But there is a down side or two. First the axle will have move fore and axle movement, so you may end up needing a longer splined area for your front driveshaft. Mine needed a 12" slip joint. That gets kind of spendy, unless you want to run a squate tubed front driveshaft. With that extra for and aft movement, you may run into the tire coming up and into the rear of the fender during the lift cycle. And as it cycles down, the axle will move farther forward.
As for street driving, under hard braking, your nost will dive down.
All in all it's six of one, half dozen of the other. A lot goes into how you set up the spring. Do you make your front mount higher or leave it level (level as in parallel to the ground)? You can dial in how the spring will react on obstacles if you place it differently.
It really doesn't matter if it's a baby Jeep or FSJ, the charateristics will be the same.
Breakfast amounts to one live toad, I choke that mofo down, and I am rest assured that nothing worse will happen to me for the rest of the day.
___________________________
CJ truck project
'18 Jeep Renegade
'15 Jeep Cherokee
Old 12-30-2008, 11:31 AM
j20brett's Avatar
Could you possibly take a few pics of the front and rear hangers? Thanks!
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 12-30-2008, 11:35 AM
Sure, when I feel like laying in the snow again.
The spring hangers are stock. The only thing that changed on the springs was the shackle move to the rear.
The front shaft is longer than stock and has longer yoke section to help with axle moving back when compressed.
Old 12-30-2008, 12:25 PM
4x4fEvEr's Avatar
The only thing I care about is bending springs and trasborg says in steep climbs the front end wanders. I dontlike that.
I'm ruunin a square shaft already and I don't care about bodydamage there's not a straight dent free panel on mine and I don't run on the road so all those concerns are out the window.
I'd like to see pics as well seen a rough country kit for $110 bucks I may get that and have at it
Old 12-30-2008, 12:28 PM
It wanders more on the pavement than anywhere else. We got used to it. It is fun to get someone riding shot gun in it for the first time.
Old 12-30-2008, 04:59 PM
jtr's Avatar
jtr jtr is offline
I am going to save my $$ and 3 link front and some kind of link setup in the rear. Early Bronco springs would work good in the front I think.
Leafs just arn't going to last long for your application, IMO.
Jeep is gone ~~ Ranger cab truck in the works
393W/C6/203-205, HP60, 14B, 12 bolt H1s, 40" Pitbull Rockers, full hydro, 4 link rear
Build = http://www.pirate4x4.com/forum/showthread.php?t=973973
Old 12-30-2008, 05:29 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
These guys (members here) have a SR kit for FSJs: http://www.tandjperformance.com/main.shtml
Old 12-30-2008, 06:21 PM
4x4fEvEr's Avatar
Yea tru links and coils would be great. Not even in the budget though
Old 12-31-2008, 11:25 AM
Long&Low's Avatar
Tell Pete you'll get less wandering with an SRS system than without, hillclimbing or not.
CJ truck project
'18 Jeep Renegade
'15 Jeep Cherokee
Old 12-31-2008, 12:21 PM
Stuka's Avatar
Stuka Stuka is offline
It should also be noted that your front drive shaft will be forced to operate at a much higher angle when the axle droops. As the pinion will point down instead of up (as it does with a front shackle). So you look fine for slippage with the square shaft, but the u-joints are going to need more angle (unless you already have 1410's or the like).
And, if you drive on the street, you will get a lot of nose dive when you brake hard as when the axle pushed back, the shackle will give, which allows the axle to move up as well.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 12-31-2008, 12:26 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
When flexing now, your pinion gets pointed towards your transfercase. When flexing with a shackle reversal, your pinion gets pointed towards the ground.
You will need to make sure that your drivelines can handle the extra angle.
You can rotate the leaf perches around the axle a little bit, but that is a lot of work for anyone who is already spring over. Plus, I wouldnt reccomend cheating it more than 2 degrees anyway otherwise it will wander like a yaht at higher speeds.
Old 12-31-2008, 12:27 PM
Dmntxn77's Avatar
Hey watch this...
I guess I type too slow... Stuka beat me to it...
Old 12-31-2008, 12:30 PM
Dmntxn77's Avatar
Hey watch this...
Anther point to cover is axle movement withing the wheelwell. Stock, the tire sits closer to the firewall than it does the bumper since it will move forward during flex. Once you switch the shackle, your axle will move the opposite direction. So, you will probably need to reposition your axle closer to the bumper so that when you flex, it does not get forced into the firewall.
Old 12-31-2008, 12:54 PM
4x4fEvEr's Avatar
Good points! I have a 1410 yoke for the front but no driveshaft yoke I gotta find one, and I could turn mine up 2 degrees no problem plus I'm already highpinion so I think ill be safe. I've got the front axle pushed forward two inches as is it was eating into my turn signals which are gone now so I should be fine if not I can always make room. I'm def going to do the shackle reversal
Old 12-31-2008, 03:41 PM
Dmntxn77's Avatar
Hey watch this...
Cool, go for it...
If I were you though, I would measure your pinion angle at full flex just be be sure. Remember, the HP D60 pinion location is only 2.25"s higher than the LP D60, so its not THAT big of a difference. It still doesnt point your pinion up.
