11-08-2017, 09:32 PM
How hard and time consuming is replacing intake manifold gaskets
Hi Everyone,
Since non of the local mechanics want to work on my jeep....I am tempted to do it myself...with limited tools.
I need to replace the intake gaskets because of a leak.
I did a search and really didnt find anything that gave a difficulty or time rating.
How hard and time consuming is it to do?
Any and all advice is appreciated.
P.S. If anyone wants to help me wrench this....pizza and chicken wings are on me
11-08-2017, 10:03 PM
we don't know what he wants.
I've done it twice on a 258 and it's not that tough so long as everything comes loose. I needed some flexible extensions that I didn't have to reach all the bolts, but I got it all to seal up properly on my first try
11-08-2017, 10:29 PM
AMC V8? Buick V8? Or I6?
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
11-09-2017, 10:07 AM
11-09-2017, 02:19 PM
It's pretty easy - did it a few times on my 360. Only tricky part is to lower it exactly so you don't have front/back movement when letting it drop.
Also - you can choose to use the end seals, or drop a 1/4" bead of RTV. I just used the RTV & it's been fine (read that seals can un-seat over time?).
If it's a V8 and a stock manifold make sure you have a helper - they are heavier than you'd think!!!
Total time with cleaning off old gasket material, pulling carb, draining coolant figure a day on the weekend.
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
11-09-2017, 10:47 PM
Sorry....AMC 360
11-10-2017, 03:03 AM
Remove the hood I made a contraption to hold the hood up with a saw horse type frame, scribe the position on the hood of the stud to allow for easy reinstallation, it is a lot easier because the intake is so heavy.
I did the RTV bead in the back,
check carefully all the surfaces on the head, I had some pitting, but it is doing well.
I pop the cover of the PCV to clean 40 years of caked oil
Check my links below for any useful picts
Michel
11-11-2017, 07:14 AM
360 AMC
Everything seems to take longer than I think it would. There is a lot of stuff to clear out of the way before you can start. I was fortunate that all the bolts came out without trouble, but my old manifold did not want to come off after the bolts were out. The darn things can really adhere themselves to the heads and block. I tapped on the thing forever trying to get it loose and ended up using a screwdriver on the end to get it to release. I was worried that any screwdriver marks would keep it from sealing, but I haven't had any problems. It is ridiculously heavy making it a challenge to lift out and more importantly to set down straight so you don't disturbe the thick RTV bead on the ends or the metal gasket that seems to want to move around as well. I used a little high temp rtv around the water openings of the metal pan, but I think the jury is out on doing that. If I remember right, I think one of the manifold bolts needed to have thread sealant applied because it was tapped into water jacket. There is a torque sequence that should be followed when installing the manifold bolts. I followed the sequence, but couldn't use a torque wrench due to space issues. Just a few thoughts.
11-11-2017, 10:29 AM
With the OE head being so heavy....would going to an aluminum intake a better option? Do know if there is any benefit but I thought i would ask.
Thanks for all the input
11-11-2017, 12:23 PM
The weight factor difference will make a difference to your back but not your car. There are better aftermarket manifolds that marginally perform better for normal street use but to spend the money "just to save weight" isn't a good economic plan.
11-12-2017, 07:21 AM
360 AMC
The darn manifold weighs 74 lbs and is hard to lift when you are standing on your tip toes. If you want an aluminum manilfold you might as well install it now, but since you probably will want to figure out a lifting devise anyway, the original works fine. I've included a link to a past discussion on the weight issue and possible ways to deal with it.
http://www.ifsja.org/forums/vb/showthread.php?t=72815&highlight=intake+manifold+w eigh
11-14-2017, 02:25 PM
Where are you in LA? I did my intake about a year ago and will be doing another one in the next 4 months or so. If you want to come up to Camarillo we can park next to each other in my garage and do them together...
There are Edelbrock Torker intakes (aluminum) on LA Craigslist often but they are not smog legal. If you have a 76 or later, the only aluminum intake you MIGHT be able to pass smog with is Edelbrock 3171 Performer (it has provisions for EGR).
If you are 75 or older, you can run a Torker but it may not be the wisest choice for a daily driver and you would have to get a different carb.
( Cherokee Build Thread)
11-23-2017, 03:33 PM
Sorry for the delay....I would be open to that but my rig is on non op right now and would not be able to get it out there.
If anyone wants to wrench from start to finish....I would greatly appreciate it
11-24-2017, 09:51 AM
you can get a day pass... from DMV or AAA if you are a member, not too sure if you have to pay for the pass, at some time they had 1 month pass for smog visit, but for a non-op, not too sure...
Michel
11-24-2017, 11:16 AM
what city are you in? I might be able to come down there...
I wont be able to until about late Dec though, if you can wait that long.
11-24-2017, 06:40 PM
Engine hoist was the only way I could get that heavy monster in. There was just enough clearance without removing the hood.
Mike
88 Grand Wagoneer
Bone stock - except the missing stuff
11-24-2017, 07:58 PM
I am in Santa Monica...
11-24-2017, 09:17 PM
Wrenchathon?
about time for a visit anyway......
I am considering pulling the heads on my '76 for a refresh soon.
tommy
'83 j10 pioneer 258/t5/208...gone
'81 j10 sportside 258/t176/208
'76 j10 shortbed 360/th400/QT
'81 j10 sportside 258/tf999/208
'74 j10 shortbed ...gone
11-25-2017, 05:20 PM
I can't commit to a specific day yet but I'd be willing to pack up and come down there sometime in late Dec.
Before starting, you will need:
1) new intake manifold gasket set
2) a gallon of coolant
3) I would get a 195 degree Tstat since we will be in there (I have a couple extra gaskets so don't worry about getting a Tstat gasket)
4) a Carb to intake gasket
5) I will bring some extra vacuum lines and fittings (I am SURE we will find some cracked hoses and we might brake a fitting)
6) It would be a good time to do your fuel filter (I have an extra brand new AC Delco one still in the box I'll sell you for what I paid for it, i think about $4)
7) LOTS of rags and a shop vac to clean whatever you need to clean while we are in there.
8) I put a super thin layer of black Permatex on my sealing surface last time and it worked well. I am not sure it is "needed" but it might be good to have.
9) probably be good to replace the PCV while we are in there too, so I would recommend ordering that
10) Last thing to buy would be a EGR Gasket if you have an EGR valve.
11) Shop manual page with all the torque specs. I have my shop manual in soft copy (79) and have a hard copy of the 82 Manual. What year is yours?
I'll bring all the tools I think we need.
Anyone else want to chime in?
Wrenchathon sounds good to me but doing 2 intakes will take most of a day. Getting the heads swapped might be a tall order for one day unless your are trailer'ing it...
11-26-2017, 09:26 PM
I worked many years at a repair shop that worked on vintage vehicles. Do not, I repeat, do not use the rubber end seals. My old-timer boss warned me against it and I didn't listen. Every time I used one of those rubber end seals it has blown out causing a massive oil leak. Do yourself a favor and get a tube of "the right stuff" RTV sealant and run a fat bead in place of the rubber end seals front and rear. Make sure you set it straight down without any back and forth movement. Set the manifold on dry first just so you can see the gap and how thick the bead needs to be to seal.
The other comments are no joke. The AMC V8 intake is inexplicably the absolute heaviest intake manifold I've ever encountered. Did intake gaskets on a Ford 352, Chevy 454 and 350, small block Ford, Buick Nailhead 425, even a Ford 460. Somehow the AMC one is heaviest. I just about destroyed my back removing mine by myself. When I put it back in, I had two other people helping me. Later on I switched to an Edelbrock Aluminum intake. Wish I had just done that to begin with.
1988 Jeep Grand Wagoneer
4" BDS Suspension Lift
Tru-Trac Rear
Howell GM TBI with Custom Tune
Thread Tools |
Display Modes |
