Old 02-21-2012, 09:51 AM
Logans Run's Avatar
Logans Run Logans Run is offline
Headlight rings
Those of you who have converted to a Rhino grille, I am just curious as to what you did to secure your headlight ring.
if you have pictures feel free to post them too.
The Falcon ... 73, 360, TH400, D20, D44 3.54 (F&R), 6" BJ's spring lift, 35"
"I've fought tougher men, but I really can't remember when."
P.S. those are some beeftastic bumpers!
My Build Thread:
http://www.ifsja.org/forums/vb/showthread.php?t=151753
Old 02-21-2012, 09:55 AM
jwalton23's Avatar
jwalton23 jwalton23 is offline
I bought my whole setup from a guy on here but I don't know which headlights they are but they bolted to the bucket and to the trim ring. There was a slot to slide the top into and one screw at the bottom. I don't have a close up pic of it or I would post it. I will take one when I get home if no one has by then.
91 Grand Wagoneer
AMC 360 / Torqueflight 727 / NPM 229
Dana 44 front and rear
6" Rustys Offroad suspension lift
BJ's quick disconnects
BJ's PreRunner front bumper with winch plate
fenders trimmed
35x12.50x15's Maxxis Bighorn mudders
Rhino grill
http://www.tnjeeps.com/
Old 02-21-2012, 10:04 AM
sld's Avatar
sld sld is offline
My buckets came from a '63. There is a slot on the top that slides down on a raised edge. It is then secured in place with a screw on the bottom.
1981 WT Cherokee Chief /360/TF727/208/ Holley 600CFM/ Performer Intake/ Edelbrock headers/ Skip White HEI, switched dizzy gear. Patriot Side Pipes.
Old 02-21-2012, 04:22 PM
rreed's Avatar
rreed rreed is offline
Yep. They're the same buckets/bezels as the CJs, if memory serves the bucket has sort of a raised bump or tab at the top that the bezel "hangs" on then a single screw at the bottom secures it.
47 Willys
75 CJ-5
81 Scrambler
96 ZJ
blakeusa's Avatar
blakeusa blakeusa is offline
You just need the older style headlight buckets that have the attaching screw holes and some have tabs. At least that is how mine work.
Think CJ's and even Ramblers used the same buckets.
1971 J4000 Gladiator w/AMC 401 Restoration Project
Old 02-21-2012, 05:30 PM
serehill serehill is offline
Gone,Never Forgotten.
OR
You can go to the hardware store buy a couple of 90* brackets & bend them a little more than 90* install it @ 12 o'clok then get some 3 inch phillips head sheet metal screws. Grind down th eheads to fit properly. Put the rim on using the bent 90* bracket to hold the top take a punch mark the bottom & remove drill a hole to thread the sheetmetal screw. Start & tighten it down. That's how mine are done. Or buy cj Buckets.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 02-23-2012, 10:57 AM
Logans Run's Avatar
what do you mean by 90 degree brackets?
I was thinking about making them, but I would like to see your set up.
My Build Thread:
Old 02-23-2012, 11:06 AM
sld's Avatar
sld sld is offline
He may be saying to take the 90 deg. bracket and form a J out of it. Of course it would all be 90 deg. angles. The bottom of the J would form the lip that the ring would sit on. Hey, I'm just guessing.
Old 02-23-2012, 11:54 AM
Yep
SLD is sort of correct. I went into the hardware section & they have these little 90 degree (About 1" x 1") shelf brackets with a 1/8" or somwhere's close hole on each side for mounting. I took them & bent them about another 30 degrees to make almost a U out of it. I used one of the holes ( On the bracket) & a self tapping screw & mounted it in the 12 oclock position on the headlight opening. the I put the ring over the area where the ring bracket on the rim fit where the clip on it latches onto the bracket. once I got it to fit by bending the bracket to fit well I took a punch & marked where the single hole on the bottom of the rim lines up with the body. then I removed the rime & drilled a small hole & ran a modified phillips head screw into the hole I drilled to hole th erim on it looks factory. The Modified Phillips head screw was one I picked up at the hardware srore aolso. It was 2 1/2" & I ground the head down smaller to fit the headlight rim better. it has been on th eCherk for 2 years no problem. the rim will not cover the entire opening unless you have added onto it to ensure it covers. you can get it close. if you work on it.
Picture of bracket
http://i.ebayimg.com/00/s/NzJYMTIx/$(KGrHqF,!k8E8DvIBUbuBPNYq1D!t!~~60_1.JPG?set_id=8 800004005
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Driver's side headlight low beam keeps burning out DanHS General FSJ Tech 8 01-05-2009 09:39 PM
Headlight Upgrade. H4 and Relays Mahamotorworks General FSJ Tech 3 12-09-2007 12:18 AM
HEADLIGHT TRIM RINGS FOR RHINO H Callaway General FSJ Discussion 3 03-06-2007 08:56 PM
Headlight rings adam_nj General FSJ Tech 3 06-13-2003 11:16 AM
