Broke the passenger side rear axle from an mid 80's Waggy / full size cherokee with a centered pumpkin. Been looking online for axle dimensions and couldn't find any. So I was hoping some of you guys know the length axle I would need, I pulled whats left of the broken axle and part of it is still inside, still need to pull the diff. I measured the drivers side at 27" and the broken axle at roughly 29.25" from back side of mounting surface, does that sound about right. Also where is the best place to get chromoly axles, the one I broke was from Dutchman. Also using this axle in a 87 YJ so not sure on the specific year as I bought the YJ used.
Broken axle Rear D44
