So, my original set of keys is starting to wear out. I would love to find a set of American Motors blanks. I bought a set on ebay and it ended up being for an earlier Grand Wagoneer. The only blanks I can find have the Chrysler Pentastar and Jeep on them.
American Motors Key Blanks
'15 Wrangler Unlimited (JKU) / 3.6L / 42 RLE / NV 241 / DANA 30-44 (3.73)Tags: None
fleabay has them sometimes but you have to be careful they are not all the same, there is a letter code on them ( like J ) so your originals have to match.....ask me how I knowAbort? Retry? Ignore? >
Tripwire, sounds like you found out the same way I just did. The door keys work well...ignition key not so much. And, for the late model GW, the code is J.
Joe, it is funny. The keys I received when I bought the rig (I was told they were the "original keys". One set is stamped American Motors and the other is stamped with the Pentastar and Jeep.'83 Scrambler (CJ-8) / 258 / T-5 / D-300 / DANA 30-AMC20 (3.31)
Check BJ's Off Road.WH
Herbina 1987 Grand Wagoneer
Let me look around and see what I have. I have extra blanks for our 78, not sure if they will be the same.1978 Wagoneer
Mods:
Looked at the blanks I have and they are all aftermarket. Like WH said, BJ's had them, not sure if they have any left.1978 Wagoneer
Mods:
Originally posted by WHSIICheck BJ's Off Road.'83 Scrambler (CJ-8) / 258 / T-5 / D-300 / DANA 30-AMC20 (3.31)
Mine was so worn, it finally wouldn't work in the ignition. I've got AAA. They came out, pulled the steering wheel and ignition, rekeyed it.
I also pulled one door cylinder, took it to locksmith, got new master to match.
I've gone to local Ace to have copies of both made, no issues.'Robert E Lee'
89 GW White w/Cordovan Interior(daughter's DD)
Originally posted by JeepJeepsterDo you all have your keys made at a dealer? Can they do that?
Or just copy the worn out originals and hope for the best?'83 Scrambler (CJ-8) / 258 / T-5 / D-300 / DANA 30-AMC20 (3.31)
blanks
I have quite a few blanksAMC V-8 FOREVER
1976 Cherokee Chief 360\4-spd(soon to be auto\ Q-trac)
1977 CJ5 "Lulu"
360\5-SPEED GRANNY\DANA300\ DANA 44s
DETROIT \POWERLOCK 4.10
37" tires, and LOTS other stuff
77 J-10 401\Q trac "Thadeus"
64 Stude Avanti 289 R2---ALIVE!
91 Dodge W350 5.9 Cummins
64 Avanti#2(R1)...Under construction
Originally posted by racegasMine was so worn, it finally wouldn't work in the ignition. I've got AAA. They came out, pulled the steering wheel and ignition, rekeyed it.
I've gone to local Ace to have copies of both made, no issues.2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
