03-14-2012, 05:05 PM
05-03-2012, 12:09 PM
This seems like a great mod...count me in.
05-09-2012, 07:54 AM
Just sent you a PM, please count me in. Thanks!
-Rob
1990 Grand Wagoneer
360/727/229
Pre-Runner Bumpers
Locked Rear
250k + miles and running strong!
73 J4600/79 J10 - Sold
05-09-2012, 12:05 PM
Gone,Never Forgotten.
PM answered
Rlars7
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
05-12-2012, 08:31 AM
Got mine in the mail yesterday! Plan on doing the install today if I find the time. Thanks!
Just bought a 1979 J20 ... still working on it..
05-12-2012, 03:18 PM
Originally Posted by serehill
Rlars7
Thank you! Would I need to remove my brush guard for install? Was under there today and it looks like a PITA. Hoping I can remove grill and install while keeping brush guard on. Thanks for the help.
-Rob
1990 Grand Wagoneer
360/727/229
Pre-Runner Bumpers
Locked Rear
05-13-2012, 08:13 AM
well
-Rob
With a little patience you can do this with out removing the grill although it will take some time so will removing the grill. The grill also can be removed without removing the brushguard. the wiring can be threaded through the holes in the grill & header panel. we did a razor that way. All you have to do is remove the headlight Bezels & trim.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
05-14-2012, 07:50 AM
With a little patience you can do this with out removing the grill although it will take some time so will removing the grill. The grill also can be removed without removing the brushguard. the wiring can be threaded through the holes in the grill & header panel. we did a ravor that way. All you have to do is remove the headlight Bezels & trim.
Great news! Thanks for all you have done, pumped about getting this in place. I may PM you for a quick how-to for removing grill without brushguard if you don't mind. Thanks again for all help.
-Rob
1990 Grand Wagoneer
360/727/229
Pre-Runner Bumpers
Locked Rear
05-23-2012, 04:27 PM
got mine!
1976 Cherokee 401 Quadratrac
4" Rough Country Spring lift 31" tires
All MSD ignition system
EZ EFI status: Running Smooth!
Dakota Seats
Powertrax No-slip lunchbox rear locker
Amp meter delete
Two Wire 94Amp Alternator upgrade
05-23-2012, 04:54 PM
I'm telling ya you can install without removing the grill.
It's not that bad. I've done several.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
06-04-2012, 08:37 PM
Success
Originally Posted by GI-John
GI john has the first fully loaded Tailgate window relay system complete with wireless remote. Testing it pretty well complete & some fitment issues are being worked out. The system was designed for the relays to go in the tailgate & we're finding that to be a challenge. The wireless remote rocks. The point is it works can be used with original switches & safety lock.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
06-04-2012, 08:58 PM
That would be
1984 Grand Wagoneer
UGLY, with 360, 727 and NP229.
Mods: All aluminum radiator, HEI, CS144
Future Mods: Rebuild heads, cam, lifters, timing chain, aluminum intake, 4 barrel, SOA & 33's
06-04-2012, 09:11 PM
lets get some preveiws
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
06-05-2012, 05:36 AM
I'm ready for this, and the remote will be awesome!!
1984 Grand Wagoneer
06-05-2012, 03:58 PM
Tailgate window bypass relay kit. I'm interested. I don't require a keyed switch in the back or the stupid safety switch. I just want to be able to roll my rear window up and down from the dash without having to get out, pop the hood and touch the long 10ga speaker wire I hacked into the window motor to the battery. LOL
1988 Grand Wagoneer currently in pieces across the shop.
06-05-2012, 06:25 PM
It'll be a while before I'm to the point of needing something for the tailgate window but I'd be interested in a kit when I get there...
David
'78 J-10; '78 J-20 8400GVW
'79 Cherokee
'50 Willys (not Willy's) 4WD Pickup
06-13-2012, 06:23 AM
I can't believe I missed this!
I have been waiting with baited breath to comment on Serehill's harness.
My original system was dead. I have a 76, so it had the older style motor and regulator.
I ended up going through eBay for a newer style regulator and motor, which wasn't compatible with the 76.
Rich to the rescue!
He built me an outstanding harness that allows me to control my tailgate window from either switch. They perform flawlessly! I also have the option to use a remote control to operate it from about 100' away. It is more convenient than you could imagine!
I would HIGHLY recommend this harness to anyone thinking about trying to repair their old tailgate system. All of the wiring, switches, and relays were replaced with high quality components that should last for the life of the Jeep. I can finally use my tailgate now, and would do it again in a heartbeat.
Thanks again Rich for such an outstanding product!
John
If anyone has any questions about this, please feel free to PM me.
Just Emptying Every Pocket
06-15-2012, 06:45 PM
Do you have any more headlight kits? Just for a two light system. Thanks and not in hurry if that helps.
06-19-2012, 11:13 AM
I'm interested in a two headlight kit as well. Do the relays have to be mounted behind the grill or can they go under the hood?
MadMax78
78 Cherokee Chief, Wide Track, 360, TH400, Quadra Trac, SOA, 35" BFG KM2, Edelbrock Carb & Intake
06-19-2012, 12:35 PM
Can't speak for Serehill or all of the harnesses he makes, but I had enough wire in the harness he built me to mount under hood. It was tight but made it.
Great quality product as well!
-Rob
1990 Grand Wagoneer
360/727/229
Pre-Runner Bumpers
Locked Rear
Thread Tools |
Display Modes |
