FWIW it would be more like 66.6/33.3 as I took a clean 5 gal. bucket, dumped in two gal. of Prestone, one gal. of distilled water. Poured that into another clean water jug to pour in the radiator (try filling your rad w/ an open 5 gal. bucket, I dare you). While topping it off I don't recall if I used water, pretty sure I just poured straight out of another leftover Prestone jug..
Well I'm confused as to why 70/30 (which is more what mine probably is) is bad; it says on the jug what 50/50 would do for you, 70/30 it indicates a higher boil/lower freeze. I've always seen/heard 50/50 or 70/30 all my life, I just figured it meant more antifreeze=better esp. after reading the jug..
I will say I've always ran 50/50 in everything else w/o issue but since this is supposed to be a tow vehicle (if it'll ever run for more than a day or two at a time) I went w/ the stronger protection of 70/30 the jug indicated.
I will try to get my hands on a shroud. So the airdam, does it connect to the stock bumper? Mine is not but there is a good lip of the 2x4 c-channel I could attach to. I'd like to see some good pics of them and how they attach. I need to check the fan clutch, as mentioned I'm not convinced the new Hayden is working any better than the factory original one. I've never heard the fan roar and even at over heating I can spin it pretty easy.
I greatly appreciate everyone's help so far, thanks all!
