This weekend my engine heated up beyond it's normal range. I figured I had a leak. Sure enough very small leak at the petcock radiator bottom. Topped up the coolant. Have to try and get new gasket but tightening helped. I also discovered that the hose to the cooler overflow tank was not connected so connected the hose.
Next day was better but still hotter than normal. I noticed that the coolant overflow tank spigot was cracked and wet but hose was properly placed.
Wondering if there is a kind of vacuum that is formed by radiator pulling coolant that is "broken" by the crack so not enough extra coolant gets pulled.
Should I be replacing the coolant tank?
Are there aftermarket replacements?
Any thoughts ?
adam
Any thoughts ?
adam
