you got my attention Jason... The tire deals look pretty sweet. What axle you got under the front of the GW?
Add another to herd....1978 J-10 build
Originally posted by fulsizjeepyou got my attention Jason... The tire deals look pretty sweet. What axle you got under the front of the GW?
I'm installing the one out of my big CJ. I was going to put it under the Cherokee but the focus I have for that one is like the Bargain Beater project, simple and stock looking.
My plans changed since I saw that 4-door wide track at FSJ Ouray this year I really like it!! The Diesel will go into it as well and I plan to make it into a vehicle that can go as many places as the wifes Grand Cherokee.Jason in the Mountains
1978 J10 LB,OE 4-speed,4:10's,4BBl,and just 85K(daily driver)
1988 Grand Waggy 8" lift 35" A/T's (under construction)
1984 CJ7 12" lift 39" Iroks 1 tons
1979 Cherokee Super Chief (under construction )
1974 J-10 LB Buick 455 BB 4" lift 33" BFG tires
1973 J-4800 LB plow truck 7" lift 255/85/16 LT Truxs MT's
ahhh... I mean the axle that is going from the GW to the J10.Flint
crap, I read that wrong. So, what 8 luggers you using on the Jtruck?Flint
I think I am going to stop by again next year and check out your back yard. I can see alot of parts .
Originally posted by fulsizjeepcrap, I read that wrong. So, what 8 luggers you using on the Jtruck?
Well I have two options....I could use both the front and rear axles out of my 73' J4800 that is now going to have a new $50.00 Chevy Dually Dana 60, sorry I had to rub it in again. The axles from the J4800 are a front Chevy D44HD and a rear factory D60 and both have 4:10's and open differentials. Our use a extra D70HD axle I have out of a Ford E350 and then switch the D70 front that I have from drums to discs.
For now I'll go with the first option because it will be easiest during the lift and also until I get a few other projects finished.Jason in the Mountains
Glad you saved the Watermelon Wagon Dude those rims are killer! Score!
Personally, since you already have a lifted monster, keep it low and strong for moving stuff around. The reason FSJ trucks were low to begin with is that they were designed for worksite duty...that's why the clearance underneath is so beautiful with no parts under the frame rail. 3/4 ton conversion sounds wise..
(one) of Steves biggest gripes with his lifted J10 was the fact he couldn't get at anything in the bed when camping..lifted sky high trucks are great for wheeling..not so much for utility.1979 Chero S "Sundog" 1979 Chero S "Hammer"
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
This is the axle I going to use in the front, it's from a 69 Dodge W300 and its a DANA 70'S
The pictures don't do this axle justice, so I put a 1/2 Ford 9-inch in the picture.
Then the axle tubes are monsterous!!! That's my size 10 work boot on it for conparison.
Since after market axle outers "C's" are becoming a little cheaper, one option is to cut the closed knuckles off and install some open 1410 U-joint knuckles. However swapping the drums to discs would be cheaper using the uglytrucking kit. So I don't know which way I'll go. Of course if I found a good core D60 somewhere that has a bad center section but good outers.Jason in the Mountains
Originally posted by Gambler68Glad you saved the Watermelon Wagon Dude those rims are killer! Score!
That's a good point however my J4800 that had almost 7" of lift and 255/85/16's in this picture.......
Even though the flat bed was a little lower than a stock bed is I don't think it changed how useful it was. I do agree I love how low the J10 is now the few times I've used it but I do want it at least eye to eye with a stock Ford high boy.Jason in the Mountains
good point..watermelons weigh less than river rock of the same size1979 Chero S "Sundog" 1979 Chero S "Hammer"
I've got one of those in my '74. Been trying to find a matching shift knob forever!
Originally posted by COLOFIREMAN85,000 original miles and a true factory granny T-18 and 4:10's . Reverse is up and to the right.1974 J10 258 T18/D20
Project since 2009. Collecting dust while in school.
2002 Tundra - Daily Driver
