Old 06-11-2012, 06:57 PM
JeepFullSizeFan1984 JeepFullSizeFan1984 is offline
Okay, I'm bringing this back from the dead....lol
Has anyone looked into the F&B Throttle Bodies setups at all? I can't seem to figure out if they include the Electronics and what not to make it work or if I need to find the tuning side for it?
Old 06-11-2012, 08:56 PM
BGW's Avatar
BGW BGW is offline
I'm just going to add my two cents. I wouldn't splurge for the Edelbrock kit just yet. As archaic as TBI is, it's really all most people need. The Edelbrock kit is a very simplistic version of MPFI. It costs too much in my opinion. The real advantage is the MPFI manifold Edelbrock makes for AMC engines. I'm working on a Ford based sequential MPFI system that uses Edelbrock's manifold at the moment. Right now, it looks like the cost will fall between $1000 and $1500. The real cost is in the programming equipment, so if more people did it, it could become quite economical. The Ford based system is light years ahead of the Edelbrock kit in terms of engine management and processing speed. It's able to keep a much tighter reign on the engine, resulting in maximum power, efficiency, and the cleanest emissions possible.
1991 Grand Wagoneer, Stock, 99k.
My buddy Sam: "...as far as gas money goes Peter's car is as thirsty as an alcoholic on St. Patricks day..."
Old 06-11-2012, 09:04 PM
fullsizejeepfreak's Avatar
fullsizejeepfreak fullsizejeepfreak is offline
HOWELL! Just because I love mine. Who else can go 15 months in a FSJ and only top up the water and change the oil? NO WRENCHING FOR OVER A YEAR! Yes, it was boring; but I survived.
87 grand waggy SOLD :-(
99 Suburban 4x4 (wife's DD) 3" lift, dyna pro m/t's
Old 06-11-2012, 09:13 PM
I only bring up F&B Throttle Bodies cause they have a EFI 6-pack for the 360 engine. I figured if I spend that kind of money, at least make it better in the performance side as well. Having a 6-pack without dealing with carbs sounds really sweet to me!
Old 06-11-2012, 09:55 PM
mattparliament's Avatar
mattparliament mattparliament is offline
I found an EZEFI system on craigslist an jumped on it, it was just tested and complete. It sits on my 401 and I love it! Starts and runs like any other modern vehicle. I did later upgrade to a new poly tank and in tank fuel pump, most of the out of tank fuel pumps create some annoying noise and I was tired of it. I would endorse the EZefi system and do it again...
1976 Cherokee 401 Quadratrac
4" Rough Country Spring lift 31" tires
All MSD ignition system
EZ EFI status: Running Smooth!
Dakota Seats
Powertrax No-slip lunchbox rear locker
Amp meter delete
Two Wire 94Amp Alternator upgrade
Small Surge Tank for Fuel Injection Wesdog Fuel Injection 5 02-18-2011 09:11 PM
90 GW restoration with fuel injection gasman66 Fuel Injection 7 11-21-2009 08:48 AM
Upgrades/Tweaks to Improve MPG prayforsurf General FSJ Tech 33 01-04-2007 10:39 PM
fuel problems Great Pharoah General FSJ Tech 9 11-02-2004 02:47 AM
Help / Vapor Lock Issue key General FSJ Tech 9 04-09-2004 10:54 AM
