  #41
Old 04-28-2019, 05:23 PM
Originally Posted by babywag
So I cannot find my adjustable pushrod...
Doing the math 18 tpi is .056 @ 1 full rotation?
Which means to obtain .020-.030 = ~1/2turn(.028) after zero lash?
Correct
Old 04-29-2019, 06:23 AM
Yes, your math is correct.
LS1 rocker puts the pushrod seat .040" lower than the AMC rocker from my '90. The AMC rocker ratio measured 1.605, LS rocker 1.715. That's just straight measuring the rocker, not the actual valve lift vs lobe lift measured with a test spring (my engine is still in pieces).
I'm going with the summit K8600 camshaft kit which as .080 smaller base circle on exhaust, .050 on the intake. So I may be able to reuse the factory pushrods on the exhaust and compress the lifter .015 more on the intake.
But the heads, deck were touched, different brand lifters, who knows how the head gasket thickness matches the oem, so I'll find out when I assemble.
Old 07-14-2019, 06:31 AM
JeepsAndGuns's Avatar
Curious if anything came of this, or has the project been shelved?
Old 07-15-2019, 11:54 AM
My engine is together with the factory rockers and pushrods, just changed the oil after break-in. I'll get to swapping in the LS rockers eventually.
Old 07-24-2019, 07:57 PM
I have a ton of stuff higher on my list but I will get to it eventually.
roller rockers o stamped? yossarian19 General FSJ Tech 3 05-23-2017 02:29 PM
AMC 360 Heads with Comp Cams Magnum Rockers Road Hammer Street & Performance 4 10-08-2015 02:19 PM
For those of you with roller rockers...have a question 78 Arizona Chief General FSJ Tech 26 12-11-2007 10:51 AM
Scorpion roller rockers on 401 baybilly General FSJ Tech 10 03-14-2007 07:26 AM
Who has experience with AMC roller rockers? TexasJ10 General FSJ Tech 7 08-16-2004 07:14 AM
