I'm trying figure out if something is blocking the vent that's connected to the gas neck or if it's normal but when I pump gas in my 77' Wagoneer it constantly trips and I have to slowly pump gas. Is this normal or has anyone else experienced this? My gas gauge also isn't working..not sure if it's related or not. Thanks!
Pumping gas problem
Fairly normal depending on where you live. The path to the tank isn't a straight enough run. Worked acceptable back in the day but todays gas pumps pump at a faster rate than they did in 70's. If your stations have those goofy Calif accordion rubber boots on the nozzle it makes it near impossible on some wags. Some folks get away with rotating the nozzle 90* or even 180*joe
Yep it's a pain when it's 0 degrees out and the wind blowing 20 mph!
Literally a painLast edited by Montana Mike; 01-30-2015, 07:48 PM."Buster" 72 Wag 360, Dana 20, TH400, BJ'S 4 INCH LIFT, 31X10.50R15
"Beula" 77 Wag 360, QTrac, TH400 all stock future doner to Buster
Montana Mike
I look for gas stations with some slope, parking downhill helps.
Still have to turn the nozzle. Gives people more time to
eyeball your jeep and get jealous. For me, "It's Paid For"
covers a lot of irritations like this.Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Originally posted by Montana MikeYep it's a pain when it's 0 degrees out and the wind blowing 20 mph!
Literally a painJeep gauges are for amusement only. Any correlation between them and reality is purely coincidental.
