So after reading the posts on here about propane, I have been puting more thought into it. I have a 401 right now. It has the holley truck avenger on it and I am kinda getting tired of the carb thing. I have a trans,t-case, and axle swap I am gonna do next year (see signature) Once I get all that done I am gonna start working on rebuilding my caddy 500. My plans were to build a nice fuel injection for it, since I was so tired of carbs. But I am a little worried about the cost of building the system (I want a MPI system, not TB) Not to mention the possiable PITA factor of tuneing it. After all the good threads on propane I was thinking, it has a lot of the benifits of fuel injection. Pressureized line, so no fuel pump. Since its a gas, no fuel bowl, and it will run at any angle like FI. It burns cleaner, motor and oil lasts longer. From what I read, its pretty easy to tune it. So I figgured I would just build the engine for propane and run that. But then I thought, what if it doesnt work out as well as I want, or becomes too mutch of a PITA because of the dis advantages. (harder to find propane, smaller tanks, less mileage, etc..) I would then have a motor with too high a compression to run pump gas. I would prety mutch have to stay with propane, or build a new engine. I dont want to put myself in a bind.
I have been tired of the carb on my 401 for a while, and I was thinking about running a TB injection on it untill I build my 500. And I just missed a complete TB system that was for sale a few months ago. But then a few days ago, it hit me like a ton of bricks. Why waste time and money building a TB system for it if I am only gonna run the 401 for a couple more years. So I figured why not start with the 401 and convert it to propane. That way if I like it, I stick with it, if not, I go fuel injection.
My thoughts are this, If they make a propane system that can feed the 401 and the caddy 500, then get that. I guess my question is DO they make a propane system that could feed a 401 and a caddy 500. What I would do it start out with it on the 401. If I like the system, the way it runs and all that other stuff, and decide I want to keep it. I would build my 500 for propane, and then swap the system over when I swap motors. Thats why I want to know if there is a system big enough for both. It would be a good start for me. I run it on my 401 as kinda a experiment to see how it runs and how I like it. If I like it, keep it, if not, start work on fuel injection. I figure this would be the best way to start, that way I can keep myself out of a bind if I dont like it.
Thoghts? Ideas? Comments?
Please, I want them all.
