Lindel.... I will let you know....
As for the kits.... they will be reasonably priced I have to figure in my time and laber plus the cost of material AFTER I find a new supplier....
blt2crl,
Not a stupid Q at all.... I'll try top explain it.
The main reason for a shackle flip (in my eyes) was to compensate the 7" I gained from the SOA.. I HATE BLOCKS!!!
Just "flipping" the shackle as you described will not give you the amount of lift needed to "level" the FSJ back out. You can do this, but still need to fab a front mount so the spring will work properly and not at an angle of up and back.... up and down is how they are designed to work.
You can "flip" the shackle like you said... but remember to to fab a front mount to drop the front of the spring low enuf to level the the suspension... and this may not be enuf to sompensate for a SOA.
A little food for thought here:
If you were flip the shackle by cutting the bottom out...the total distance the spring moved is about 6" in the rear.... giving you a total of about 3" of lift AT THE CENTER OF THE SPRING (geometry works well on paper for a visual on this using inches here with ANY length of line)...not...BUT now you must "level the spring somewhat by fabbing a front mount of about 6" down to give the 3" in front needed to level the spring... thus giving you only 3" of total lift.... you would still need a 3" block to get your 6"
Why not just order a 4 spring 6" suspension system and SCREW BLOCKS!!!! you will be much happier... TRUST ME....
[ October 23, 2001: Message edited by: River Beast ]
blt2crl,
