Was going to throw the new motor in today, but it started getting dark by the time I had moved the engine to street level. I took the hood off and noticed that the torque converter has a little surface rust. I spun it and it made a noise like it had a little dirt or sand behind it. There was no sand inside the torque converters sleeve. Just in the bellhousing which I cleaned up. There were also a cpl of metal shavings on the bottom of the bellhousing. They are the size of a dime cut in half and are paper thin.
QUESTIONS....
Should I clean up the surface rust on the torque converter?(motor is painted and pretty...lol.)
What Is the SEAL directly behind the torque converter...Is it hard to replace??? (torque converter oil seal????)
Should I replace the torque converter...Truck ran fine from Maryland to Ky last year....the sand is prolly from when I sandblasted the frame. The motor was still attached to the tranny at the time...the metal shavings were what concerned me.
Thanks, jim
QUESTIONS....
Thanks, jim
