Old 06-03-2017, 11:34 AM
CutterN55's Avatar
Dutchman axle shafts bearing failure?
Couple years ago I purchased some dutchman shafts from BJs for the rear waggy D44 that i rebuilt from bare housing. Up until yesterday they've been flawless with a few wheeling trips, no mud or water and about 13k miles of DD duty on 37s and recently 35's on the CJ7.
Well i just grenaded the drivers side wheel bearings and blew out the seal on my way to work. Took a bottle and a half of gear oil to limp home. I thought it was just a seal but when i pulled the axle shaft, a pile of what was left of the bearings spilled out.
This seems like super premature failure. I know everything was surgical clean and well packed with grease on install. Anybody know if Dutchman has been using crap bearings or what? Theres no manufacturer stamp on the bearings whatsoever. Im kinda pissed about it.
Also, im thinking i might have to pull the diff and make sure the carrier and pinion bearings arent full of metal.
Both BJs and Dutchman are closed today.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 06-03-2017, 01:53 PM
seems your pushing the limits of the axle with 37's on a full size, could be a low quality bearing but may also be the axle housing is bent and loaded extra pressure on the axle shaft and bearing?
Old 06-03-2017, 03:12 PM
CutterN55's Avatar
This is a CJ7 with my waggy axles in it. 37s are good on a light jeep like a CJ with a 44. I havent been beating on it. I'm rocking now. Im leaning towards low qual bearings. The back retainer ring that the seal pushes against failed on both sides from what i can tell. Drivers side fragged, pass side was on its way out with about 1/8" of play in and out on the shaft.
ROMANS 12:1-2
'89 GW deceased
Old 06-03-2017, 09:58 PM
J20 project's Avatar
If the destroyed side got really hot.....please replace the axle. I learned the hard way on this. I also struggle to call bearings which you have wheeled on for two years...bad
Seems you may have used them up.
J20
BP Drivetrain...........
775-537-7918
Old 06-03-2017, 10:16 PM
Randyzzz's Avatar
Randyzzz Randyzzz is offline
Things I have learned after running a Waggy 23 rear axle in my LS Scrambler with 35"s:
1. Be prepared to replace bearings yearly.
2. A leaky seal corresponds with twisted splines and a slightly bent shaft. Also yearly...
3. There's no substitute for a full floater.
4. Should have put in a D60.
Randy S.
It's not what you Buy, it's what you Build.
1987 J20 SOLD
1966 Waggy SOLD
1970 Waggy SOLD
1982 Scrambler SOLD
1981 Scrambler - Current Project/Keeper
Old 06-03-2017, 11:41 PM
It may not be your only problem but crap bearings are a big problem these days. look at your bad bearing and I bet it's a Peer or some other ching chong ding dong brand.
Even Timken can be from Mexico or who knows where now day, same with BCA and most others. I've found SKF to be the best most of the time, US , England , France and Germany.
I will not install a bearing made by slaves in a 3rd world nation . not so much a political statement as I just don't like changing bearings all the time.
Old 06-06-2017, 07:13 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
Cutter, shoot me an email with pics to ryan@bjsoffroad.com and I will check with dutchman
BJ's Off-Road
ryan@bjsoffroad.com
Old 06-16-2017, 09:39 AM
CutterN55's Avatar
Thanks brother. Will do.
email sent with pics. waiting to hear back.
ROMANS 12:1-2
'89 GW deceased
Rear Wheel Bearing replacment How To Billygoat General FSJ Tech 12 04-18-2019 10:06 AM
upgraded axle shafts jeeping1974 Off-Road FSJ Tech 28 05-29-2008 11:55 AM
replacement axle shafts 2yellowmonkeys General FSJ Tech 5 11-27-2005 01:16 PM
NP229/Dana44/Front Axle Disconnect...Scottie? Joe Guilbeau General FSJ Tech 8 03-07-2003 12:44 AM
Axle bearing info...READ THIS River Beast General FSJ Tech 4 02-17-2001 08:12 AM
