Old 10-09-2013, 07:47 PM
Miraphone186's Avatar
Miraphone186 Miraphone186 is offline
Stopped raining, checked the timing and its something like 15 BTDC.
1990 Grand Wagoneer DD
Old 10-09-2013, 08:04 PM
serehill serehill is offline
Gone,Never Forgotten.
If it's carbon it's because it's running rich
All the carbon in the world won't make it ping.
Stated in this thread more than needed what it will be.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 10-09-2013, 11:11 PM
I adjusted the timing to 10 BTDC as per oem specifications and took her on a freeway run again. I only got it to ping once right when I got off the freeway, maybe a small improvement? I've been trying to get it to ping stationary in gear so I can take a better video but no luck so far.
Old 10-10-2013, 07:31 AM
vacaisle's Avatar
vacaisle vacaisle is offline
snide. snarky. grease covered.
This indicates to me that you have other problems. You won't get it to ping standing still. It needs to be under load aka moving. I'd check the egr operation. Whats the temperature after a ride on the highway? Also if you have a vacuum pump you should check your vacuum advance. Read this
http://www.ifsja.org/forums/vb/showthread.php?t=84586
Do a search for ping on this site and you'll see all the causes and then address each one.
89 Grand Wagoneer
145,000 miles, TFI, MSD 6a
Old 10-10-2013, 10:00 AM
Not entirely true.
If you have bad gas it will ping in gear standing still(foot on brake) putting a load on engine(reving engine).
Old 10-10-2013, 10:54 AM
At correct idle speed with vac hose plugged? If so it's way advanced.
Old 10-11-2013, 04:02 PM
Rich88's Avatar
Rich88 Rich88 is offline
You didn't say as much but you imply that this is a sudden on-set. In which case maybe your vacuum line to the EGR came off or is cracked & leaking. Pinging caused by other reasons such as timing or carbon build-up don't just start all off a sudden.
And if you can diminish or eliminate the pinging by backing off on timing, all the more reason to suspect EGR not working. Thing is, backing off on timing will now lower performance.
Old 12-29-2013, 07:02 PM
Cha05Twn07's Avatar
Cha05Twn07 Cha05Twn07 is offline
Were you able to get the pinging/knocking issue resolved?
1991 Jeep Grand Wagoneer
www.1991jeepgrandwagoneer.com
Old 12-30-2013, 08:05 AM
OutrageGIS's Avatar
OutrageGIS OutrageGIS is offline
Low oil
You probably checked this, but if your oil level was really low, a sharp turn could send the oil to one side of the pan letting the oil pickup draw a bit of air (instant valve clatter) and then be re-submerged when the oil settles in the pan after the turn / acceleration. This could happen fast enough to barely affect the pressure indicator. Seen this before on a really leaky engine.
(sigh) knocking from engine... CJ the noisemaker General FSJ Discussion 19 11-14-2010 02:16 AM
I got a pinging problem..... ne715 General FSJ Tech 2 09-10-2009 11:47 PM
Am I Timing this correctly????Need Help with Pinging schnerdad General FSJ Tech 9 05-11-2007 09:38 PM
More Pinging & Spark Knock Questions Anteloper General FSJ Tech 9 12-05-2005 03:16 AM
Why pinging returned after new EGR and TFI? tito General FSJ Tech 14 03-03-2004 09:06 AM
