Old 07-24-2011, 05:56 PM
The PIG Smith's Avatar
King Browless
Another A/C Question: York or Sanden
After reading a few A/C postings here recently, I have a question of my own.
While I do not know, I am fairly certain that my York A/C compressor on my J10 project is bad.
It has been open to the elements (no hoses connected) for a while.
My simple question to the group, which is the better compressor pump? York or Sanden?
The reason for my question is that "if" my York is bad and I need to replace it, then I would want to go back with a York or a Sanden?
It's my understanding that the compressor mount is the same.
The only difference are the adapters on the end of the hoses to the compressor pump.
It makes sense to go back with what my rig came equipped with.
However, if I am spending $$$ and the Sanden is the better compressor, then why would stick with the York?
Also, the adapters maybe a non issue, as the hoses look like as if they should be replaced.
If this is the cause, then I would have new hoses built with the correct connectors from the Sanden compressor.
Now, I fully understand that only way I will know what is good and what is bad is by taking to a competent automotive A/C Shop.
By asking this question now and gathering information, I will be prepared when the A/C Shop says,
"Mr. Smith, in addition to all tat is wrong with the A/C System on this truck, your compressor needs to be replaced."
I would like to be ready and reply, "Here, install this good working compressor."
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 07-24-2011, 06:40 PM
The Colonel's Avatar
I'm partial to the Sanden compressor.
It's more efficient, takes less HP to run and is R134A friendly.
However, if there is going to be a huge cost difference I wouldn't bother.
Old 07-24-2011, 07:10 PM
addicted's Avatar
addicted addicted is offline
Big Meanie
If it came with a York keep the York as the mounting brackets are different and the Sanden was a 3 year compressor '89-'91 maybe '88, so the brackets are much harder to find.
Originally posted by Ristow
i bet it was Simon....
Old 07-24-2011, 07:18 PM
Chevelleguy's Avatar
There are aftermarket brackets available that allow you to bolt the Sanden to the York engine mount. It is a very simple plate with 4 tabs.
The Sanden is a much quieter and more efficient unit.
Old 07-24-2011, 07:21 PM
Daddio's Avatar
Daddio Daddio is offline
My vote would be for the York. They are tough, self oiling, and larger displacement (higher btu's). When was the last time you heard someone say my ac system was too good and I want to down size?
One the down side, it probably take more power to turn which would result in more fuel consumption. It also may not be as compatible with 134a.
'88 Grand Wagoneer, towing package, 360 .030, Holley Street Dominator intake, Holley Projection, rv cam, double roller timing chain, HEI, CS144, oil pump mid plate, Thorley Headers, BJ's 3" exhaust, and more...
http://www.youtube.com/watch?v=xWWCj...layer_embedded
Old 07-24-2011, 07:25 PM
serehill serehill is offline
Gone,Never Forgotten.
Really??
I'm partial to my sanden. It did not bolt right in if you have a york you will have to either find a later model compressor mount of get an adaptor the two are not the same. I like the rotatry screw compressor (Sanden) design for several reasons. I don't think that the sanden is built as tough as the york. The reciprical action of the york though takes more HP to run & makes more wear & tear on the compressor & motor. It took me HP to operate the York. I can't even tell when my sanden is running. The York manifolds bolted right on my Sanden. I got 90 degree 134 connectors that went right where the old shreader valves were. & I'm good. I ran 134 both ways & it does seem to work better on the Sanden but is not a day & night difference. Know that the york is a dinosaur & will only get more expensive I decided to change. Your call But that was my decision.
It was just time to move on from a power eating inefficeint compressor. There's a reason why they are not made anymore or come on anynew vehicle.
Hey they make OK air compressors even then only a subsitute.
Update after being notified I found I was misinformed & these Sandens are not Rotary style but piston style I want to ensure info is accurrate. Whoops.
Old 07-24-2011, 08:35 PM
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
I found a sanden at yard the other day, guess I should go grab it, I got a ton of yorks though so that's what I used on the install on the one I just did.
Chad
"Let's see that Red Blue Green **** sucker build one of these without duct taping it together!"
88Wag
87J20 Member, FSJ Prissy Restoration Association
83Cherokee WT
82J20
Parts vehicles: 1.5 Wags, 3.5 J20's, 1 J10 1 J300
Old 07-24-2011, 10:50 PM
jeeper54's Avatar
jeeper54 jeeper54 is offline
When I was trying to repair the a/c on my 86 waggy I found a Sanden kit ( compressor, mount adapter and hose adapters) on ebay. Don't recall the price but it was something cheap enough for me to consider.
Currently without
Formerly
1986 G.W. 360
1986 Eagle Wag
1985 G.W. 360
1984 Eagle Wag
1981 Wag 360
1978 Wag 401
1981 Cherk W/T 258
1966 Wag Super 327
Not counying XJs'.
[Did have a 94 & more recently a '97 GC with 5.2. for awhile. Just not the same! Now have the FSJ blues!
Old 07-25-2011, 05:20 AM
sld's Avatar
sld sld is offline
I have looked for a York rebuild kit, however I just find links to make an air compressor.
1981 WT Cherokee Chief /360/TF727/208/ Holley 600CFM/ Performer Intake/ Edelbrock headers/ Skip White HEI, switched dizzy gear. Patriot Side Pipes.
Old 07-25-2011, 05:32 AM
the sanden is a better,and more efficient. my '83 will be getting changed over to a sanden very soon.
the sanden has 7 small pistons inside,as shown here.
http://www.sanden.com/originals/imag...uide_Rev.2.pdf
Old 07-25-2011, 07:21 AM
710 Burner's Avatar
The York setup had a lot of great features, but it is very inefficient. The Sanden can move the same (and in some cases more) amount of freon with less pulsing and less parasitic HP loss. Plus it takes up about 2/3 the space.
Mark B. Jones
Old 07-25-2011, 08:38 AM
addicted's Avatar
Big Meanie
Well since it's so easy and I didn't realize how easy it was. Go with the Sanden they are better compressors. But the factory set up is still fairly hard to come by.
Old 07-29-2011, 03:10 PM
badaboom's Avatar
badaboom badaboom is offline
freon Capacities
Can someone chime in on refrigerant capacities?
Or any other specific specificaitons -
AMC/Jeep factory charge capacities
York R12 = ? LBs.
Sanden R134a = ? LBs.
And has anybody heard of ES12 or some such animal supposed replacement or can be used in replace of R134a
1981 Jeep J10 Laredo, 401-V8, 625 Carter, Lunati 262/268, Edelbrock Performer, MSD Ign., Hydroboost, Hyd. Clutch, Flow Cooler WP, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, FiTech400 to come - IN PROCESS Bling Bling Cha-Ching
Old 07-29-2011, 03:42 PM
derf's Avatar
derf derf is offline
360 AMC
On my truck, I'm planning my AC upgrade as soon as I do my camshaft swap this fall. The condenser is already coming out. I plan on using a sanden with an adapter bracket. Either I'll make a bracket or just buy one like this: http://www.oldairproducts.com/catalo..._69000017.html
I'm going to need new hoses anyway. They're going to have to be custom made. I may as well just get ones that attach to a Sanden.
Try out my gear ratio calculator
Old 08-16-2011, 10:12 AM
badaboom's Avatar
A/C hoses
If you are using gen2 interior duct work / components with the newer gen3 Sanden Compressor will you need hoses with SAE fittings to the duct / interior components to hook up and metric to the compressor?
Compressor hoses -
gen2 york all SAE
gen3 Sanden Metric
Hybrid gen2/3 sae and metric
Experiences?
Old 08-16-2011, 10:23 AM
thatguy
Posts: n/a
how do I know which compressor is on my 89 wag?
Old 08-16-2011, 10:34 AM
'89 should be a Sanden.
The photo below is from my '89 with the Sanden:
Old 08-16-2011, 12:53 PM
Walt's Avatar
Walt Walt is offline
It's supposed to have a 7 cyl compressor, but the 258 engine application came with a smaller displacement compressor (5 cyl sd-507) and I have run into several sources that list the 507 for both 258 and 360 applications, so watch out. It will still fit; my current truck had a 507 in it when I got it. The first place I went to get a replacement handed me another 507.
I'd need to search this site to find the p/n again, but I found a new compressor with a ford sticker on it that is the same as the jeep sd-709. Apparently some ford dealer installed a/c used the same compressor.
EDIT- here's my thread on the ford p/n compressor: http://www.ifsja.org/forums/vb/showthread.php?t=27576
If you get a new replacement sanden you'll have to work out something custom for the charging ports. I think Spectre installed one with custom hoses?
90 G Wag.- New Motor/Trans/TC...Soon to have TBI!: CS-144 Alt; Parallel Flow A/C Condenser; Read this BEFORE you install an HEI ignition module!
Old 08-16-2011, 05:10 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
I've found that the yorks take alot of power, the engine really bogs down when it cycles on, but they cool really well. Take our Rambler for example: It's been converted to R134 and you do loose some cooling capacity when you do the conversion, but it still cools better than any of our newer cars without youk compressors and with R134 from the start.
Old 08-16-2011, 07:42 PM
Tin Medic's Avatar
Tin Medic Tin Medic is offline
Loose (lug)Nut(s)
My 89 came stock with a York and so did the one down the street. Wierd.
Sons Waggy - 89 GW 360/727/208, 30x9.5x15 Destination M/Ts, Warn Lock Out Hubs, Razor Grill
Tramp - 85 CJ-7 Renegade FI 258/T5/D300, D30 w/ARB Air Locker, AMC 20 w/Posi Unit, 33x12.5x15 Goodyear MT-R's, Hella E-Code lights, VIAIR OBA System, Warn 8000lb Winch
Replace York with Sanden AC Compressor? Beach_Dude General FSJ Discussion 7 06-20-2011 08:52 AM
A/C question from the smart FSJ folks bjersr General FSJ Tech 8 06-18-2010 05:14 AM
A/c question Wagoncrzy General FSJ Tech 2 05-17-2009 05:37 AM
A/C mounting brackets York to Sanden kenny1221 General FSJ Tech 2 08-09-2003 03:19 AM
