Old 04-17-2011, 06:27 PM
Dr. Marneaus's Avatar
Aftermarket tach mounting locations?
Hey hey hey!
Lets see where some of you mounted your tach (other than in a home made gauge cluster)? The most logical place seems to be the shift column, but the whole thing moves when you shift, so the gauge moves with it.
I cannot for the life of me find a better spot to mount the gauge though. I was thinking to the inside of my glovebox door, so if I wanted to see it i could just open it...I'm kinda out of ideas.
pics are good!
Originally Posted by FSJunkie
The Mag - The Wag
Old 04-17-2011, 06:28 PM
Mounted mine to the A-pillar
-Jonny B.
D20 - Twin Stick'd
F D44 - 4.10, Eaton E-Locker
R D44 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 04-17-2011, 06:33 PM
-Jonny B.
D20 - Twin Stick'd
Old 04-17-2011, 07:25 PM
tyrodtom tyrodtom is offline
I took the stock cluster, moved the amp gauge to where the temp gauge is, ( that wasn't easy ) then put the tach in the right hole.
Then mounted 2 5/8 oil pressure and temp. gauges on the steering column.
82 J10 swb, 360,Offy dual port, edelbrock 600, DUI,3.5in. exhaust, T15, D20 twin-stick, Dana 44 fr, Ford 9in.3.70 rear, 31in. BFG
Old 04-17-2011, 07:49 PM
drlocke's Avatar
drlocke drlocke is offline
Roadside Mechanic
The lower left corner of the windshield area as pictured seems to make the most sense. It seems to be a choice between having the tach in your face so you can see its action and run into a tree, or have it in a less ergonomically friendly spot and hunt for it and run into a tree. Next to the speedo would be your best bet if you can put whatever was there in a different spot without too much ado. Not an option with a '68 FSJ's cluster, so I'm probably going to rely on the earballs for my engine RPMs.
Old 04-17-2011, 08:50 PM
I always liked the Tach. mounted on the hood
Old 04-17-2011, 09:04 PM
Chrome's Avatar
Chrome Chrome is offline
Ph.D in Redneckology
X2 on the A pillar.
..,=====,o00o
//__l_l_,\____\,__
l_---\_l__l---0
lllllll0
_(o)_)__(o)_)--o-)_)___
Old 04-18-2011, 04:32 AM
DonC's Avatar
DonC DonC is offline
I'd like to see that; can you post a picture?
Old 04-18-2011, 04:52 AM
drlocke's Avatar
Roadside Mechanic
Good, traditional spot. But around here you have to keep brushing the snow away from it.
Old 04-18-2011, 12:05 PM
i guess 1 lil hole on drilled into my a pillar wouldn't hurt anything TOO much...
how to find a spot for the tranny temp gauge, haha.
all my other gauges are mounted on the AC unit at the tranny hump. out of the way, but you def. need to look down away from the road to check on them.
(old picture of old instrument panel, etc)
The Mag - The Wag
No spark with HEI after installation and removal of tach...requesting some help!! shiner2001 General FSJ Tech 3 11-24-2010 01:22 PM
"Factory" Tach install KaiserMan General FSJ Tech 12 10-13-2010 03:49 PM
H.B. 2186 Anti Aftermarket Bill Randyzzz Land Use Information 0 02-11-2009 01:28 AM
seat bracket mounting locations J10 ? badaboom General FSJ Tech 4 12-02-2005 06:51 AM
Aftermarket gauge locations chrism General FSJ Tech 4 08-06-2002 11:43 AM
