Old 11-11-2010, 05:21 PM
CJ the noisemaker's Avatar
CJ the noisemaker CJ the noisemaker is offline
(sigh) knocking from engine...
For some reason my engine is now knocking, not ticking like the last one, but knocking. I don't understand it since I got this engine with (claimed) 67,000 miles, and I barely put 4 on it. I just changed the oil, oil pan gasket, and rear main seal. The oil I am using is 10W40 (was using Motorcraft 5W20 synthetic).
I just hope I have to overhaul it, and not find myself replacing another engine.
Or AMC killer is my name
CJ
[/color][/size] -1985 Ford LTD Country Squire "Rarity" - 302/AOD
Old 11-11-2010, 05:47 PM
Tornado230's Avatar
Can you isolate the point where the noise is coming from?
Back in the late 70's they had problems with the 232/258 developing a knocking noise. It came from the cam moving and allowing the timing chain to bounce around front to rear.
The guy at the local garage took a motor apart and couldn't find any bearing problems. The AMC dealer pointed him in the direction of the camshaft.
Evidently cam bearing wear.
There should be a service bulletin out on it, but who in the world would have that.
You may have a different problem.
Old 11-11-2010, 05:54 PM
Eaglefreek's Avatar
Eaglefreek Eaglefreek is offline
Mine 258, in my Eagle, starting knocking Sunday. I turned back home but didn't make it. It turns out it wasn't my engine but my torque converter. The snout ripped right of the converter.
86 AMC Eagle 258/4.0 head
87 AMC Eagle 5.3L, 4L60E, Explorer 8.8, Dana 44 on 35's
Old 11-11-2010, 07:55 PM
Dadgumit CJ, cant you be NICE to them once in a while... J/K.
I hope its nothing major...
Do you have the old block to start building on?
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 11-11-2010, 08:10 PM
1jeep4me's Avatar
1jeep4me 1jeep4me is offline
Just got this letter from your Jeep.
Dearest CJ,
Please treat me like a gentle lady. Ill take you to the ends of the earth. But realize I am a woman of age and need to be treated with dignity and respect.
AHHH hog wash!
CJ stop beating that girl of yours to death........
She is new to you so gently shake her down and make sure ALL items to keep up that engine are done.
Jenny SOLD
1982 Cherokee Chief Wide Track
4 inch lift
360 ci Edelbrock carb and intake
115K
Daisy
1970 Wagoneer by Kaiser
350 Buick/Turbo 400
3.73:1 Limited slip
41K original miles
Lilly
SOLD your a good girl LILLY!
1973 Commando by Jeep
304 2V 3:73 Limited Slip
3 Speed
93K original miles
Old 11-11-2010, 08:16 PM
amcpsycho2's Avatar
amcpsycho2 amcpsycho2 is offline
I bought an Eagle wagon that a used car lot had sitting there.I had run across it a year earlier,when the previous owner had it.He had traded it in to the car lot.The guy at the car lot said it had a knock,motor was bad.He said he had his mechanic look at it,and the conclusion was it had a bad motor.I fired it up,and yes there was a knock,but if you put it in gear,stepped on the brake and lightly on the gas,the knock went away!I gave the guy $150,took it home,pulled the tranny and transfer case.The flexplate/flywheel was cracked completely loose from the crankshaft.I installed another flexplate,replaced the front pump seal,as long as I was in there.No more knock,drove the car for 3 more years,then sold it,still a good motor.It would be worth a check of the flexplate.
You say psycho like it's a BAD thing!
Some days it's just not worth chewing thru the restraints!
Old 11-11-2010, 08:33 PM
The last block had a stress crack in cylinder three where that piston failed.
So I guess I should try an Iron Duke 151?
CJ
Old 11-11-2010, 08:35 PM
Originally Posted by amcpsycho2
I fired it up,and yes there was a knock,but if you put it in gear,stepped on the brake and lightly on the gas,the knock went away!.
That is what my engine is doing, so I'll check that out.
CJ
Old 11-11-2010, 09:16 PM
mattmopar440's Avatar
Could be somthing as simple as a harmonic balancer or timing issue dont always assume the engine Toast
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 11-11-2010, 09:40 PM
1jeep4me's Avatar
Hope for the best prepare for the worst.
Jenny SOLD
4 inch lift
115K
Daisy
350 Buick/Turbo 400
3.73:1 Limited slip
41K original miles
Lilly
3 Speed
93K original miles
Old 11-12-2010, 09:44 AM
SEdmonds's Avatar
SEdmonds SEdmonds is offline
CJ - check out this thread:
http://theamcforum.com/forum/258-camshaft-exessive-end-play-knock_topic13417_post118121.html?KW=engine+knockin g#118121
Old 11-12-2010, 10:11 AM
Did you tork all the main caps to the correct specs? I swear we need to start a program like the Ham radio folks have where an older experienced operator called an Elmer takes a new-by under his wings and teaches them the ropes. Corey this is no dis on you just some old guy ranting about how we don't teach our kids how to survive these days.
Old 11-12-2010, 10:13 AM
Hmmmm... Wasn't there just a post about RMS and a hammer? Right?
Old 11-12-2010, 10:54 AM
Pry bar
Old 11-12-2010, 11:04 AM
Originally Posted by CJ the noisemaker
Next up was the rear main seal, and even that was troublesome. The low end came off after some scraping, but the upper seal in the block didn't budge, even with some pounding on it. So I left it as is and put the lower seal in, so far it has been holding up with no excessive leaking.
My mistake. I confused pounding with hammer.
Old 11-12-2010, 11:16 AM
Actually I did use a hammer, but with a screwdriver settled on the seal. Had to do it on my last engine, but it came out with one light tap.
This one stayed in one place tap after tap, blow after blow.
(plus I was told not to hammer on the crankshaft)
And if and when I overhaul/rebuild this engine, that upper seal will need to come out then.
CJ
Old 11-12-2010, 11:20 AM
80lbs. right?
Then yes.
Ever since I got my wag, I have been teaching myself (and learned through IFSJA) how to work on it and other vehicles. However I haven't done this long enough to hear all of the sounds (except that ticking)
CJ
Old 11-12-2010, 04:30 PM
SEdmonds's Avatar
Try backing off the ignition timing a little and see if that helps.
Old 11-13-2010, 08:15 AM
jeeperjoe's Avatar
jeeperjoe jeeperjoe is offline
knock knock
does it get worse when you accelerate? ignition detonation sounds, are different than crank and rod noise, anything coming from the bottom end is usually accompanied by visual metal sparkels on the dip stick, a way to isolate noise, use a long socket extension, holding it up to your ear, touching various areas of the block, head, timing cover, trans bell, while running, tapping the throttle, to get the most extreme area of noise pin pointed, hope this helps.
1st year willys pre release model, 4bt cummins turbo diesel, sm465/203/205 o.r.d. gear doubler, 3 sticks, gear vendors o.d. d-60 rear powerlock, d-44 front powerlock, 2 tanks/39 galls, 20 mpg, ac, cruise, tilt, axle under sp/9" lift, 400k miles, restored in 1985, custom leer shell modified from 7' ranger, fold down bed, hickey sidewinder winch/12k
Old 11-14-2010, 02:16 AM
jeepjseries's Avatar
jeepjseries jeepjseries is offline
80lbs. right?
Then yes.
Main caps are 100 ft lbs.
HDC CTO (???) Gil General FSJ Tech 46 03-31-2010 10:23 PM
V8 Engine Mounts TINMAN93 General FSJ Tech 7 09-16-2006 09:06 PM
Mikes Engine Swap-o-rama will e Events 32 01-08-2006 12:19 AM
7 miles per gallon ?!?!?!?! jode General FSJ Tech 33 03-13-2004 02:32 AM
Help please Dan G General FSJ Tech 36 09-02-2002 08:47 AM
