Old 12-24-2019, 05:16 AM
hudwagon hudwagon is offline
lift option
guys, i installed new USA stock springs on my 89 GW currently have 235 75 r15 tires looks great but id like to get a 31 " tire on it so i should have bought the 2-1/2" lift springs what are my options to fit the 31's? without changing out the springs again? Can I fit 31" tires i dont off- road this jeep i have others to do that with. just like the look.
David
Old 12-24-2019, 07:25 AM
wincher's Avatar
wincher wincher is offline
Hi David,
I have 31" on my chief and they look to small.
I would get on 33".
(Have seen a chief with 37" :-)
In germany a got the tip to go to a "spring smith" to give the stock springs more curve and therefore more lift.
Old 12-24-2019, 08:04 AM
You can add a FSSR 2.5" lift that uses your current springs. Also, look on my site for other Lift accessories such as the front receiver tube:
https://rocklaurencevintageautoparts...ackle-reversal
Old 12-24-2019, 05:04 PM
thanks guys !
Old 12-26-2019, 04:55 AM
wincher's Avatar
thanks!
79 chief 360amc
02 wj 4.7HO Overland
Old 12-27-2019, 02:44 PM
Originally Posted by wincher
Hi David,
I would get on 33".
If you have a chief, I assume it's wide track (most are). Our WT Fender wells are MUCH bigger than a NT and can fit much bigger tires.
79 Cherokee Chief
Old 12-27-2019, 04:07 PM
gopher_6_9 gopher_6_9 is offline
Exactly whole different beast. I am running 32x11.50s with no rubbing except at full flex in the rear it would kiss inner fender just enough to scuff under coating on the inside wheel well.
1983 Cherokee W/T
360
727
Old 12-29-2019, 04:50 AM
wincher's Avatar
Yes it is a WT.
Will go to 33 with the shackle from rocklaurence or giving my springs a better curve.
79 chief 360amc
LIFT HELP FOR 38.5 SXS PLEASE jeepsparky Off-Road FSJ Tech 24 04-10-2011 01:52 PM
I'm looking for a 3'' lift.....is RC my only option? foureyes General FSJ Tech 8 03-31-2011 09:42 AM
Family Wagon Lift Question MoppTopp General FSJ Tech 13 09-19-2007 08:11 PM
Opinions on BJs 2" lift Kali General FSJ Discussion 8 07-29-2007 08:07 PM
I want 5" lift...how to do it??? rockcandy General FSJ Tech 4 02-22-2004 02:26 PM
