Old 12-02-2019, 01:33 AM
j20krawler's Avatar
j20krawler j20krawler is offline
Talking New amc 360 from BJ
After years of putting my truck on the back burner I am in a position to finally start doing just about everything it needs. As the title states I’m doing a new long block 360. I’ve talked to one of the owners at bjs and he’s got me pretty setup with what I’m going for. Reliability or as much of it as I can get.
Are there any ifsja and bj’s off-road coupons anymore? Haha I tried bj100 code and it didn’t work.
Going to do roller timing chain, RV style cam, oil line modification, flexplate and balancer balances rotating assembly and everything else stock.
Any suggestions? comments?
I will be running it with a carb for a bit while I address other things on the truck but plan on goin fuel Injected and electronic ignition dist.
Thanks! So excited to have this thing running like it should! Any advice appreciated!
Old 12-02-2019, 04:30 AM
Don't need to do the oil line modification for your stock rebuild, save the money.
Old 12-02-2019, 08:12 AM
Ive got the 360 rebuild from BJs. They did a great job getting it to me in Florida and they decked the block, milled the heads and and milled the intake of the heads for the intake to seal correctly. I purchased the OEM rebuild but would definitely get the cam next time.
Old 12-02-2019, 11:57 AM
80Limited 80Limited is offline
Just got an email from them today about 10% off site wide for Cyber Monday.
Enter code CM2019. Says for this week only.
Old 12-03-2019, 03:36 AM
j20krawler's Avatar
I did just that! Almost 400 dollars off the order! so stoked!
Thanks guys I will have to keep the progress posted.
Old 12-03-2019, 02:00 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
There should also be a discount for IFSJA members, I believe you need to email them with your username here and they add it to your account. I doubt that will stack with the coupon code above, but worth a shot.
Old 12-06-2019, 02:36 AM
killed many motors. never saved one.
Old 12-12-2019, 02:26 AM
j20krawler's Avatar
Meaning? You killed many motors and the oil line mod didn't save them?
Old 12-12-2019, 04:43 AM
I think all he is saying is don't waste your time sand money on this modification, not needed unless your turning this motor at high rpms for long durations.( which is what I said also)
Old 12-12-2019, 04:23 PM
j20krawler's Avatar
Cool thanks for The advice, rookie mistake but I had bjs do the oil line mod as I think it was randy at BJs said to go ahead and do the mod. I’m assuming the block wiull come with the mod installed. Now I’m just waiting here which Ian the hardest part.
Old 12-12-2019, 04:46 PM
Crankyolman's Avatar
I'm just curious about 2 things.
#1 How much extra did the oil mod cost?
#2 Why buy from BJ's and not just go directly to S&J engines in Spokane?
'72 J4500
Old 12-15-2019, 02:25 AM
j20krawler's Avatar
The oil line mod from
Bjs was an extra 175 bucks I believe.
I got 10% off on cyber Monday
And honestly I didn't have a clue about S&J and liked how randy helped me out over the phone and also gave me a lot of info on fuel injection and other stuff I want to do to this 360.
I looked around on the web and didn’t find S&J when looking for amc 360 blocks
Old 12-16-2019, 11:53 AM
SC/397's Avatar
SC/397 SC/397 is offline
Wow, I only charge $20.00 to put the internal oil line in.
I guess I need to up my prices!
I have 360 blocks and complete cores stacked up if someone wants one or six.
Old 12-17-2019, 11:22 AM
Originally Posted by SC/397
... if someone wants one or six.
HAHAHAHAHAHAHAHAHAH!!!!
Angela's Revenge 4X4 Road Rally, Madison, Indiana 3/7/2010 RALLYMAN Events 2 01-27-2010 04:04 AM
Curious - why is a 304 flexplate different from a 360? tgreese General FSJ Tech 3 09-28-2008 04:51 PM
will a 2barrel carb off 360 fit 304? Robber80 General FSJ Tech 7 05-03-2006 06:39 AM
best carb for OFF ROAD performance on a 360 robselina Off-Road FSJ Tech 19 04-28-2003 05:41 PM
