Old 11-08-2019, 02:05 PM
Towtruck's Avatar
Towtruck Towtruck is offline
Air Conditioning System - 81 J10?
I removed the original factory AC from my truck about ten years ago, and am in the process of reinstalling the same system (with R132 hoses and a replacement compressor). I think I have all the parts, but don't see a typical hi/low pressure switch with wiring that would cycle the compressor clutch. The wiring diagram for the early AC does not depict a switched clutch....so I guess the compressor runs continuously when the AC is switched on. I'm just double checking with the experts to be sure I'm not missing something. I'm obviously not an AC guy. Thanks.
___________________________
Old 11-08-2019, 08:35 PM
Mikel's Avatar
Mikel Mikel is offline
Someone more knowledgeable than me will correct me, but I think it's the thermostatic switch (the temp knob in the controller) that does that.
1969 M715 6x6
1963 J300 Swivel frame
Old 11-09-2019, 07:45 AM
Towtruck's Avatar
Makes sense to me...thanks.
Old 11-11-2019, 08:19 PM
'89_Wagon '89_Wagon is offline
I can't speak to early FSJs, but my '89 has 2 points that would turn the compressor off.
Low pressure switch: This is a fail safe in case refrigerant escapes the system, which would prevent the compressor from burning out. Mine is wired in-line with the clutch switched 12+ wire.
Thermistor: A thermistor probe sits in front of the AC evaporator core, with resistance varying with temperature. A module in my '89 reads the resistance and cycles the compressor as needed. I imagine something more analog would replace the module in your earlier FSJ.
I've heard the thermistors are hard to find, but my FSj manual does provide the resistance chart if you need that.
Old 11-12-2019, 08:10 AM
Nope, there's a module with a switch that sets inside the plenum that has a Temp' tube with it. It senses the temp' and cycles the compressor. Your AC control panel should have two switches: Fans Speed / Temp
Old 11-13-2019, 08:57 AM
This seems like an option for the later GW in case the board blows out in the module or a source for thermistor probes can't be found. Is this sort of like what the earlier FSJs use? The probe would sit in front of the evaporator core?
https://www.summitracing.com/parts/fss-35845?rrec=true
Oddly enough, my wife's Passat AC stopped blowing air during a long drive but the blower was definitely spinning. After turning the temp UP, air started coming out again. The problem, ice had formed on the evaporator core. The module should have prevented that.
Old 11-14-2019, 07:46 AM
Yep, that looks like it. I didnt know that anyone made a replaement.
Old 11-14-2019, 09:02 AM
Towtruck's Avatar
Since the recent cold snap slowed me down with this reinstallation, I think I'll add a high/low switch to the old style system. Seems like a worthwhile safety feature, and I need to have that particular hose modified for a better fit anyway. I guess it would be wired in series between the fuse and compressor clutch?
Old 11-15-2019, 05:44 AM
Locked and Loaded's Avatar
Locked and Loaded Locked and Loaded is offline
I also have an 81. But with a 258. I added a low pressure switch to my drier years ago.
Drink more water.
"Nothin' ain't worth nothin'.
But it's free"
Kris Kristofferson 1970
1981 J10, 258, T176, NP208
Old 11-15-2019, 10:52 AM
letank's Avatar
letank letank is offline
the OEM was a low pressure switch positioned next to the battery. In most newer system you can swap a binary switch, Low and High pressure combo, they are often part of the filter/dryer. There are even triple switch "trinary".... to activate the condenser fan
Michel
Air Conditioning Noise medinajim2000 General FSJ Tech 4 02-27-2009 09:59 PM
takin the air conditioning out...Help!!!! cosmo General FSJ Tech 10 02-02-2006 01:35 PM
"an exhaust system can also be too efficient." Jerk General FSJ Tech 25 09-12-2002 03:58 PM
Air Conditioning jod man General FSJ Tech 11 11-28-2000 12:13 PM
